It is currently Sat Apr 20, 2019 11:53 pm
PostPosted: Sun Jul 08, 2018 1:54 pm
Does anyone know of a drill stand that would fit a Dewalt hammer drill D25013 or alternatively a drill stand that has an adjustable collar that can go wider than the standard 45mm?
Steph
PostPosted: Sun Jul 08, 2018 5:27 pm
Old School Chippie
Has thanked: 799 times
Been thanked: 1597 times
I'm not at all sure why you'd want to mount an SDS drill in a drill stand, however, are you sure that the collar is bigger than Euro-standard collar (which, incidentally, is 43mm - not 45mm)?
In my own experience of SDS drills (which encompasses Bosch, Hitachi, Metabo, Makita, Atlas-Copco, Kango, etc) manufacturers don't go out of their way to make any provision for their drills to be mounted in a drill press. Typical problems include a tool release collar or chuck which is of greater diameter than the collar, non-circular collar (with detentes for the handle to mount onto), very short collar (too short to actually hold in a drill press), etc. Looking at the picture of yours I suspect that you'd struggle to insert it into a Euro-standard 43mm drill press - which is the standard that has been around since the late 1970s. The Euro-standard 43mm collar was adopted by every European and Japanese manufacturer between the mid-1970s and mid-1980s (even British firm Wolf adopted it eventually, as did the mighty Black & Decker) and there simply is nothing else available these days. With all the drills deemed suitable for mounting in a drill press coming with a 43mm collar why would anything else be needed?
On the other hand it may be possible to get hold of an old Wolf or van Dorn drill press which has an adjustable clamp, as these were certainly made, but any such item would be at least 40 years old, or more like at least 60 years old in the case of van Dorn (a one-time subsidiary of Black & Decker which disappeared before they moved from Harmondsworth to Spennymoor in the 1970s) and these drill presses might well require modifications (i.e. "butchery" with an angle grinder or hacksaw) to meet your requirements. Below is an example of a possibly suitable Wolf ES14 drill press:
although the top "horn" might need to be ground/cut off to accommodate the DW SDS drill. These can often be picked-up complete with a working drill (which might require a little bit of TLC - normally just new brushes) for £40 to £50 but at the age they are be wary of cracks, missing bits and excessive rust and expect tom do a bit of renovation as well because these items have generally spent much of their lives out in unheated, damp garages and sheds.
Whatever else, you should never use an SDS drill held in a drill press attachment with hammer action switched on - it just isn't safe.
PostPosted: Sun Jul 08, 2018 11:28 pm
Has thanked: 103 times
Been thanked: 260 times
I had just that Wolff drill stand. Never used it so I stuck it on eBay and got a pretty decent price for it.
