It is currently Wed Apr 24, 2019 9:07 pm
PostPosted: Sat Jul 07, 2018 7:46 pm
Has thanked: 7 times
I’ve recently moved into a new-build in Scotland.
I want to replace a light fitting in the dining room and fit the replacement light so that it’s centred above the dining table.
I believe there’s a regulation that says the light must be 30cm from the nearest smoke detector.
My questions is - which part of the light should be 30 cm away from the smoke detector
* the part where the cable enters the ceiling?
* the nearest part of the of the ceiling bracket?
* the actual bulb itself (where the heat will be generated)?
* somewhere else?
The lights my wife wants fitted are suspended, so the actual bulb will be about 60cm from the ceiling.
(The light fitting is this one: http://i2.cdscdn.com/pdt2/7/8/3/1/700x700/egl9002759943783/rw/eglo-loncino-1-94378.jpg)
any advice much appreciated!
thanks,
vulpi
PostPosted: Sat Jul 07, 2018 8:32 pm
Has thanked: 41 times
Been thanked: 1470 times
There appears to be no such building regulation that requires 30cm away from a light fitting, how ever most manufacturers recommend the part of the light fitting that is on the ceiling be a minimum of 30cm away from the edge of a smoke detector.
PostPosted: Sat Jul 07, 2018 8:49 pm
Has thanked: 1001 times
Been thanked: 1897 times
Building control in my area require a smoke alarm to be at least 300mm away from a light or from a wall and at least 3m from a cooking device. This is in Scotland which may differ from other parts of the uk
For this message the author steviejoiner74 has received gratitude : vulpi
PostPosted: Sat Jul 14, 2018 10:17 am
Hi Stevie, I'm in Scotland too, so same rules would apply.
and this is the bit I'm enquiring about - if there should be 300mm between the smoke alarm and the light, my question is which part of the light? Is it one of the options I listed in my original post?
PostPosted: Sat Jul 14, 2018 12:06 pm
Has thanked: 1235 times
Been thanked: 1110 times
I don't know for sure, so this is just opinion, but isn't it usually assumed that "minimum distance between" means "At the nearest point" without reference to which part of something?
PostPosted: Sat Jul 14, 2018 12:32 pm
You are both right.
If you have a pendant lamp, the smoke detector should not be within 30cm of the ceiling rose (or what ever holds it to the ceiling) If it was the actual fitting (shade) that means every time you change the shade you would have to move the smoke detector.
Like wise if it was a "Pie dish" light (or bulkhead style) the detector should be at least 30 cm away from it. If you put it 35 cm there is never a problem.............unless your ceiling is not wide enough In which case you have no choice, but you should never mount it in the top of the apex, it should be 10cm down minimum
For this message the author someone-else has received gratitude : vulpi
PostPosted: Mon Jul 16, 2018 9:43 pm
Yeah agreed, that definitely sounds most likely - I may just have been overthinking it.
PostPosted: Mon Jul 16, 2018 9:47 pm
The ceiling 'bit' is a bar-style, around 18" long, so I've fitted it such that the nearest part of this bar is about 350mm from the smoke detector.
Thanks for your help!
