It is currently Wed Apr 24, 2019 9:19 pm
PostPosted: Mon Jul 02, 2018 11:32 am
Hi, looking for a bit of advice - I've done a 3m and a 4m extension before and used a standard pitched roof from the house - the pitch and the span was just within regulation for the 4m extension.
The question is now I'm planning a 5m extension on my new house - what would be the cheapest and easiest way to do this as obviously the span exceeds the maximum for timber joists.
Any help appreciated !
PostPosted: Mon Jul 02, 2018 11:41 am
Has thanked: 416 times
Been thanked: 1550 times
Use larger timber - (roof timbers are rafters, joists are laid level for floors), I've used both joists and rafters in over 7m spans before now so the span is not a problem with the correct sized timber.
PostPosted: Mon Jul 02, 2018 12:06 pm
Thanks for the advice, would I then need a steel purlin underneath ( the extension is 8m wide so timber won't do)?
PostPosted: Mon Jul 02, 2018 12:14 pm
Has thanked: 1001 times
Been thanked: 1897 times
Can you not get trusses made from a truss manufacturing company? They are all engineered,made for you and light and easy to install.
PostPosted: Mon Jul 02, 2018 12:51 pm
Has thanked: 65 times
Been thanked: 678 times
iirc the min pitch is 13º and a max of a 150mm head lap
what sort of tile ? cement, clay or slate ? BC with usually be ok with a minor spec change as long as you not in a conservation area
both Marley and Redland have the specs on there site most tiles are 15º or greater
