It is currently Sun May 19, 2019 11:43 pm
 Post subject: multi tool blades
PostPosted: Wed Jun 20, 2018 9:02 pm
Has thanked: 54 times
Been thanked: 1 times
hi
what kind of blades are suitable for cutting through nails
 Post subject: Re: multi tool blades
PostPosted: Wed Jun 20, 2018 9:14 pm
Has thanked: 84 times
Been thanked: 196 times
Ones that cut metal, especially steel, which needs finer teeth (like a hacksaw) than blades to cut wood or aluminium.
However, are you just cutting exposed nails - use an angle grinder with a 1mm thick disc - or are the nails embedded in wood? In which case the fine toothed metal blade, and the angle grinder, will overheat in the wood.
Please explain.
PostPosted: Thu Jun 21, 2018 9:03 am
Has thanked: 65 times
Been thanked: 685 times
There are multiple threads on the subject - have a look at saxton blades
https://www.saxtonblades.co.uk/
Metal cutting blades
https://www.saxtonblades.co.uk/fein-mul ... tal-blades
PostPosted: Thu Jun 21, 2018 7:35 pm
Has thanked: 42 times
Been thanked: 587 times
and if they are old fashioned cut nails then theres little chance of anything touching them in a multi tool in my experience
For this message the author fin has received gratitude : Ferny1
PostPosted: Thu Jun 21, 2018 9:24 pm
Has thanked: 710 times
Been thanked: 2042 times
what exactly are you trying to do ??
yes the metal blades will do it but can be an expensive slow task in some situations
PostPosted: Sat Jun 23, 2018 8:32 am
sometimes I may have to adjust a stud wall that has been misplaced and i thought if i had the correct blade I could cut through the nails in no time make a job much easier.
PostPosted: Sat Jun 23, 2018 10:28 am
if you can prize them apart a milimetre or two it will be much easier
dont forget the reach off a blade is around 1 1/2" so may need to cut from both sides
For this message the author big-all has received gratitude : Ferny1
PostPosted: Sun Jun 24, 2018 10:03 pm
Has thanked: 105 times
Been thanked: 363 times
I was using the Bosch wood+ metal blades for most of my loft conversion. They happily chop on through the odd 4" nail if youre sensible with it.
No good for modern screws though.
For this message the author Hitch has received gratitude : Ferny1
