It is currently Sun Apr 21, 2019 9:21 pm
PostPosted: Wed Jun 20, 2018 10:04 am
Has thanked: 32 times
Been thanked: 26 times
Hi
I have seen a table online, 3 pics attached. It seems to be oak but not sure if all panels are solid wood or part veneer?
PostPosted: Wed Jun 20, 2018 10:31 am
Has thanked: 656 times
Been thanked: 1861 times
It looks solid to me. :thumbright:
Painting with BIN
For this message the author dewaltdisney has received gratitude : yartin
PostPosted: Wed Jun 20, 2018 11:43 am
Any advice on how easy would be to sand down by orbital, belt sander or 1/3 sander and poly urathane varnish the table top? and if it would look good!
PostPosted: Wed Jun 20, 2018 11:56 am
A random orbital sander would do it. Progressively finer papers. I think that has been stained so it might go patchy as you cannot get all the stain out. Try and find a hidden area to experiment. If you get it bare I would use a water based lacquer as poly darkens over time. Go careful. It would be easy to mess it up.
Painting with BIN
PostPosted: Wed Jun 20, 2018 12:01 pm
Has thanked: 6 times
Been thanked: 2 times
Seems to be a solid one :hello2:
For this message the author elenagilbert has received gratitude : yartin
PostPosted: Wed Jun 20, 2018 12:38 pm
If stained and can't get all stain out and patchy, can I stain using water based the whole table to uniform shade then apply water based poly?
PostPosted: Wed Jun 20, 2018 1:33 pm
It is never successful I have found. It is the nature of the wood absorbing stain deeper in some areas than others which makes it difficult to sand back. It may be a coloured lacquer though and this lays on the surface. You will only find out when you experiment. To be fair it looks quite good, I would leave it be and use it as it is. :thumbright:
Painting with BIN
PostPosted: Wed Jun 20, 2018 2:10 pm
Has thanked: 45 times
Been thanked: 750 times
Probably a combo of solid pieces for the structure and some veneer sections. Very difficult to say for certain as you can't see the end grain on the panels.
PostPosted: Wed Jun 20, 2018 2:19 pm
I was going by the middle picture of the table top extender. You can see the reverse of the panel that the fields are made from boards so I think it is solid.
Painting with BIN
PostPosted: Wed Jun 20, 2018 2:23 pm
Yes definitely solid there, I was more thinking about the larger panels.
We have a table that is mostly solid wood, legs, aprons etc, but the main panel is definitely veneer and very thin so it would be impossible to sand. Don't want the OP to find out the hard way! :lol:
PostPosted: Wed Jun 20, 2018 2:27 pm
Yes, agreed, I think Yartin would be best advised to leave it as is :thumbright:
Painting with BIN
PostPosted: Wed Jun 20, 2018 6:34 pm
Has thanked: 1550 times
Been thanked: 3892 times
Late to the party, I'd say the centre decorative panels were most likely veneer... outer frame is obv. solid.
PostPosted: Wed Jun 20, 2018 8:04 pm
Has thanked: 1234 times
Been thanked: 1110 times
Agree with the above, I think a lot of this furniture might be "solid wood" but it's strips of inexpensive solid wood put together and veneered.
The frame looks solid, but I'd be wary of sanding the panels.
PostPosted: Sat Jun 23, 2018 10:27 am
Has thanked: 1 times
Been thanked: 46 times
If its solid Oak then it will be very heavy, try and pick it up is my advice, it could be that the legs are hollow, ie made from four sections of oak glued together, have seen it done on "Solid" Oak and "solid" Acacia tables. Nos
