It is currently Sat May 25, 2019 8:12 am
PostPosted: Sun Jun 17, 2018 10:02 pm
Has thanked: 49 times
Larger disc ones seem to be high power and low rpm
Smaller discs the opposite- how do I decide please?
PostPosted: Sun Jun 17, 2018 10:59 pm
Has thanked: 416 times
Been thanked: 1565 times
Horses for courses: what do you plan to do with it?
A 9" angle grinder is a bit of a beast to control compared to a 4", which is all I've ever needed as a chippy.
For this message the author ayjay has received gratitude : Jumanji95
PostPosted: Sun Jun 17, 2018 11:20 pm
Has thanked: 710 times
Been thanked: 2043 times
pi R Squared means the outer edge goes 3 times the speed so a 4" disc will go 3 times the speed so higher rotation wont be a problem
where as a 9" disc needs to rotate perhaps 60% slower to give the same cutting edge speed
For this message the author big-all has received gratitude : Jumanji95
PostPosted: Mon Jun 18, 2018 4:36 am
Has thanked: 105 times
Been thanked: 363 times
What do you want one for...?
For this message the author Hitch has received gratitude : Jumanji95
PostPosted: Mon Jun 18, 2018 5:40 pm
I want one for various stuff- cutting wood,metal, various diy for my project motorcycles. Sometimes I grind away the rivet on the masterlink of a motorcycle chain, so that it can come undone and a new chain put on. Grind away the head of stripped screws so they can pop out. Grind away flaky very sticky rust on exhaust headers with a wire wheel.
Cut off the exhaust catalytic converter from the main exhaust and attach a new tube with exhaust clamp (can't weld yet nor do I have equipment- totally new to diy) so that the exhaust can sound obscenely loud when engine running :) etcetera etcetera. No big DIY stuff for the home. Most of my work is for cars and bikes.
PostPosted: Mon Jun 18, 2018 5:49 pm
Has thanked: 65 times
Been thanked: 687 times
A good 4" grinder will do, you don't use a grinder for cutting wood unless you like clouds of wood smoke, For rust removal or cleaning use a flap disk
Whats you budget ? they range from £30 up into the £100's
For this message the author Bob225 has received gratitude : Jumanji95
PostPosted: Mon Jun 18, 2018 10:04 pm
So you deffinately want a 4.5" or 5" one then. 5" tend to be the more industrial end of things, 4.5" or 115mm is the norm for DIY type ones.
I'd steer clear of the very cheap (Lidl/Challenge etc) and buy a branded one. They tend to be much smoother running and less vibration. You could pick up a basic Blue Bosch or Hitachi for under £40.
I use grinders a lot, they are the only two brands that last us in the workshop. (although the more industrial models)
Get yourself some reasonable discs too, cheapo ones are a false economy, and just plain nasty to use.
Norton, 3M, Flexovit, Klingspor are all good brands that are easily gotten hold of.
A flap disc is handy for lighter duty deburring, and cleaning up. The thin 1mm cutting discs are fantastic, just dont force them or put side loads on them.
For this message the author Hitch has received thanks - 3: Bob225, Job and Knock, Jumanji95
PostPosted: Tue Jun 19, 2018 12:17 pm
Don't forget a pair goggles, glasses or face shield and a pair of decent gloves - ear plugs or ear defenders are a must tooo
There called death wheels for a reason.
PostPosted: Tue Jun 19, 2018 12:30 pm
I've bought this:
https://www.howetools.co.uk/dewalt-dwe4 ... 4-12-115mm
