It is currently Sat Feb 16, 2019 7:26 am
Post new topic Reply to topic  [ 17 posts ]  Go to page 1, 2  Next
 Post subject: KVM Switch
PostPosted: Sat Jun 02, 2018 9:01 pm
Has thanked: 57 times
Been thanked: 1 times
Just received my KVM switch from eBay, I wanted to use one screen from my Mac Mini to switch to the CCTV recorder - no joy!
Is the use of this switch limited to PC's only?
Cheers,
Graham.
 Post subject: Re: KVM Switch
PostPosted: Sat Jun 02, 2018 9:27 pm
Has thanked: 69 times
Been thanked: 142 times
I know nothing about Macs (though I have an Android tablet, on which what I refer to wouldn't work) and nothing about CCTV. You have not specified make & model or further details so this could be barking up the wrong tree.
But in the nineties & noughties, a KVM switch, to me using them then, meant Keyboard Video Mouse so you could connect two separate computers to one desktop. (Conversely a Reverse KVM meant you could connect keyboard, video and mouse in one room to a single computer (with ditto also connected) in another room. I used both with positive results.
Then, keyboard & mouse were either PS2 or USB connections and video, VGA. What is that you've bought?
PostPosted: Sat Jun 02, 2018 9:36 pm
Has thanked: 39 times
Been thanked: 1426 times
If your CCTV DVR has a VGA output it should work.
I have a 4 way KVM switch, i just tried it, it does work.
The date is when I received it, so I know when it fails how long it lasted.
PostPosted: Sat Jun 02, 2018 11:57 pm
Just trying with the displays at present, but cant get the CCTV on the display.
The display flickers about 1Hz when using the switch (Apple Mac Mini) - also cant get individual screen just a mirror.
PostPosted: Sun Jun 03, 2018 12:31 am
graham101 wrote:
(Apple Mac Mini)
erm................
I have one of those too.
But I don't use it much, my KVM switch is also connected to a pc and sometimes my laptop. Have you a laptop or another pc you could try?
PostPosted: Sun Jun 03, 2018 9:16 am
Has thanked: 61 times
Been thanked: 645 times
Whats the make and model of the KVM ?
The mac is dvi, what is the output of the cctv ? composite ? if so what convertor are you using ?
Be aware there are 2 types of dvi, DVI-I and DVI-D
PostPosted: Sun Jun 03, 2018 12:45 pm
Thanks Bob, I am using a Apple converter, which I think came with the Mac Mini (5years old now).
I may abort as cant get the CCTV working at all using the VGA output.,,,,,,,,,,,,,,,,,,,
https://www.ebay.co.uk/itm/253484546711 ... 3484546711
https://www.ebay.co.uk/itm/2-Port-TV-Bo ... 2749.l2649
PostPosted: Sun Jun 03, 2018 1:01 pm
The VGA on the DVR may not be sending the correct sync signal - I take it that you get a signal if you plug the DVR directly into the monitor ? If not have you enabled the vga in the setup ?
edit, have you set the screen resolution in setup ?
Have you tried the hdmi out ? (on the dvr)
PostPosted: Sun Jun 03, 2018 1:55 pm
if you mean one of these
Then, I can't see that being the problem.........i have one too.
As bob said, what happens if you connect your dvr VGA output to your monitor VGA input?
PostPosted: Sun Jun 03, 2018 2:49 pm
Yes that is the converter (Apple's supplied output to VGA), the monitor that I am trying to use only has VGA so not tried the DVR's HDMI but it works connected directly to the monitor via VGA.
I just thought this switch would save space and money by not buying another monitor!
PostPosted: Sun Jun 03, 2018 3:20 pm
Not been asked yet, so..............
Will your mac's display show on your monitor if you use the KVM switch?
PostPosted: Sun Jun 03, 2018 3:32 pm
Yes, but just a mirror of the other display, cant get it to be 2 indy displays like I usually have set up. No control of this switched display.
When I switch it comes back to the Mac display after 1/2 seconds!
PostPosted: Sun Jun 03, 2018 6:58 pm
I know this sounds daft, but its only an idea, can you post a picture of your KVM switch as it is set up right now. (like I did with mine)
PostPosted: Sun Jun 03, 2018 7:23 pm
Sorry someone-else, packed it away as needed to setup the CCTV system.
Perhaps I need to find another solution or buy another monitor!
PostPosted: Sun Jun 03, 2018 7:47 pm
I am wondering is it your KVM switch
New one on ebay less than £10
But that said a separate monitor for your CCTV is always a good idea. You can "watch from the corner of your eye" and just look at it.
