It is currently Mon May 27, 2019 8:34 am
 Post subject: Plasterboard line
PostPosted: Sun May 27, 2018 9:30 am
Has thanked: 135 times
Hi, I need some advice on what I can do to remove this plasterboard line prior to painting ?Image
 Post subject: Re: Plasterboard line
PostPosted: Sun May 27, 2018 11:34 am
Has thanked: 3 times
Been thanked: 138 times
the two tones of paint show up the line.
it looks like where the boards met at a join but the join was not taped or there was a small difference in the two surfaces.
could it be that the lower wall is solid plaster on brick and the upper wall is a stud partition?
PostPosted: Sun May 27, 2018 11:55 am
Has thanked: 416 times
Been thanked: 1566 times
Is it flat (i.e. all in the same plane) if you hold a straightedge vertically across the line?
PostPosted: Sun May 27, 2018 11:58 am
It’s all plasterboard dot and dab.
PostPosted: Sun May 27, 2018 12:00 pm
It’s not flat.
PostPosted: Sun May 27, 2018 12:45 pm
Has thanked: 1002 times
Been thanked: 1897 times
This is a poor way of installing plasterboard in houses and it’s always going to crack as it’s joined along a timber that had a certain degree of movement and it’s also been done in one big joint.
Plasterboard should be staggered in a stair opening and joined well below or above the floor line of the first floor.
Dig out the filler,scrim joint and plaster or easifill.
This will always crack tho I’m afraid.
For this message the author steviejoiner74 has received gratitude : Sparky70
PostPosted: Sun May 27, 2018 12:50 pm
Has thanked: 796 times
Been thanked: 896 times
Sparky70 wrote:
It’s not flat.
Yuk then. One option would be to do some heavy sanding to lose some of the joint. In the process the plasterboard my get damaged a bit ... then tape and quality filler over it[*]. What I mean is to lose the step but little you can do about the angle. Paint it with a matt paint so it reflects the light less (it seems to be matt anyway) and if you are worried about scuffs etc. then use a cleanable/scrubbable matt (acrylic) paint which has a bit more seen than matt.
[*] Toupret makes an ultra fine scrim tape which is supposed to be placed over a joint and be covered with just paint instead of filler. I found I still had to use filler over it but you will need much less filling than using a standard plasterboard jointing tape. Sorry http://www.toupret.co.uk website is down I can't check details.
For this message the author OchAye has received gratitude : Sparky70
PostPosted: Sun May 27, 2018 1:22 pm
Sparky70 wrote:
It’s not flat.
That's always going to be a problem as the light is hitting it differently and showing it up.
It would only ever be a partial success, but removing about 600mm above and below the existing joint and replacing with fresh p/b in one piece (i.e. moving the joint) might be the best option.
Edit: I thought I'd posted this a half hour ago (had to stop and hoist wife onto commode - real fun!)....but I may as well stick it up as it's already written.
For this message the author ayjay has received gratitude : Sparky70
PostPosted: Sun May 27, 2018 8:30 pm
Old School Chippie
Has thanked: 809 times
Been thanked: 1616 times
There is another approach, possibly. Make-up a wide skirting board with mouldings on both top and bottom edges and apply that to the wall over the joint. I've seen that done in old buildings to disguise a transition from plaster on brick to lath and plaster on studs, but I'm not sure how good it would look
For this message the author Job and Knock has received gratitude : Sparky70
PostPosted: Sun May 27, 2018 11:04 pm
It’s still done in timber frame houses(large expensive ones anyway) where high class finishings throughout a home are used. A hardwood bead/plate is incorporated to cover the movement joint and can look ok if done correctly.
For this message the author steviejoiner74 has received gratitude : Job and Knock
PostPosted: Sun May 27, 2018 11:18 pm
Old School Chippie
Now that is a surprise!
PostPosted: Mon May 28, 2018 8:07 am
Ok, thank you for your replies, I will try to sand it first and repair, if thats not good enough will get it re- boarded and skimmed.
