It is currently Fri May 24, 2019 6:45 am
 Post subject: Shower and combi
PostPosted: Wed May 23, 2018 5:06 pm
Been thanked: 1 times
I have a question regarding combi boilers and showers. We had a new combi boiler installed around the end of last year. The shower used to run from a water tank in a cupboard upstairs which fed a pump and the temperature of the shower could be controlled from a dial on the front.
After the combi was installed the pump and tank were removed as the plumber said it could now come straight off the mains. The shower was then scalding hot. The plumber returned and fitted a pressure reducing valve in the loft. The shower then took around an hour to get up to a suitable temperature and this was after the water temperature was raised to the maximum(65’C)on the front of the boiler and once scalding adjusted to a lower setting (40’C)There was also no control from the shower front anymore as this just made the shower go ice cold.
Last week the shower stopped drawing hot water as the boiler wouldn’t come on when the shower was turned on. Another plumber came and had a look and said we have to rip out all the pipe work from the bathroom to the loft as this is the wrong type of shower( mixer shower) for a combi boiler.
Does anyone have a simpler solution to this problem?
For this message the author Lc1 has received gratitude : instash28
 Post subject: Re: Shower and combi
PostPosted: Wed May 23, 2018 5:15 pm
Has thanked: 327 times
Been thanked: 975 times
65 degrees? Sounds familiar; what make is the boiler?
Is the cold supply to the shower also off the mains or is it still on the old cistern?
PostPosted: Thu May 24, 2018 5:07 am
Boiler is an independent combi 30.
I’m not quite sure where the cold water is coming from but the second plumber did mention that the bathroom toilet may also need some work as the first plumbers must have made some adjustments.
In the cupboard where the original tank was the shower hoses are plumbed to the existing pipes, I assume one is the hot water from the boiler but I am not sure where the cold water comes from, mains or other.
Shower is a triton.
PostPosted: Thu May 24, 2018 8:15 am
Has thanked: 840 times
Been thanked: 941 times
Do you still have a tank in the loft full of water?
If so is there a pipe from it that is not capped off anywhere?
Dave
www.drlgas.co.uk
PostPosted: Thu May 24, 2018 8:28 am
Yes there is a tank full of water in the loft. I believe it has black padding around it. Not sure if any pipes have been capped off I will have to check.
Thanks.
PostPosted: Thu May 24, 2018 8:07 pm
Sounds as if the cold may still be from the loft tank then.
If so this is completely wrong and would explain your combi problems.
All hot and colds must come from the cold mains supply on a combi.
Dave
www.drlgas.co.uk
