It is currently Fri Mar 22, 2019 1:08 am
PostPosted: Mon May 21, 2018 8:25 pm
Has thanked: 86 times
Been thanked: 58 times
Some of Makita's machines use 2x 18v batteries at once, to make 36v. I've not got any experience of this method, are there any limitations or problems with it?
Kev
PostPosted: Mon May 21, 2018 8:48 pm
Has thanked: 74 times
Been thanked: 164 times
In my personal and limited experience, no.
We have (i) a DLM431 Lawnmower which is great for the wife to cut two smallish areas that I can't get to with the ride-on. Two x 5Ah batteries easily last each session.
(ii) so impressed, I followed this with a DUC353 chainsaw, utilising the same two batteries. Brilliant, except cheap replacement chains are a false economy, OEM parts last far better.
Batteries recharge quickly enough for us, about a hour, though probably wouldn't suit a tradesperson unless he invested in three pairs - 6 x £65 each!
For this message the author arco_iris has received gratitude : Kev888
PostPosted: Mon May 21, 2018 10:25 pm
Thanks, thats good to know. Seems quite flexible, to have batteries suitable for smaller tools and simply double them up for bigger ones.
Kev
PostPosted: Mon May 21, 2018 10:48 pm
Old School Chippie
Has thanked: 791 times
Been thanked: 1576 times
I have the plunge saw (DSP600) and I've hired the 36 volt (2 x 18 volt with an adaptor) and there are only upsides AFAIK. Makita's tools seemingly all run on any mixture of appropriate batteries (i.e the batteries must be 3Ah or above) and will run with one part discharged battery and one fully charged one quite happily. You can also have different capacity batteries. So, for example, the tools I've used will run with any combination of 3, 4, 5 or 6Ah batteries. The only downsides to this are that the tools will protect themselves and the batteries, so if one battery discharges before the other one it will stop and warn you. One thing I'll say about the 2 x 18 volt kit is that it certainly seems to have a fair old bit of oomph (at leaast in comparison with 1 x 18 volters).
For this message the author Job and Knock has received gratitude : Kev888
PostPosted: Mon May 21, 2018 11:38 pm
Thanks, thats really good to hear. I'd thought there may be more restrictions than that, but it sounds even more flexible than I realised. Seems very viable indeed.
Thanks again
Kev
PostPosted: Tue May 22, 2018 12:09 am
Old School Chippie
Flexible enough for me to seriously consider a DLS110 (2 x 18 volt version of the LS1019) SCMS, It isn't perfect, but the fence is a great step-up from the LS1016/LS1018 saws, the double rild at the side of the saw are a real space-saver and the scales (mitre and bevel) are far more legible than all earlier models. At over £700 (bare), though, it may be a year or two before I pull the trigger.....
PostPosted: Tue May 22, 2018 10:48 am
Thats quite a cost, but it does look to be a very capable tool, especially if you've a need to work without the cord.
My main interest at the moment is the wide range of Makita tools which will (sensibly) use the exact same battery, from modest drivers with one battery to twin-battery hedge cutters etc. Could suit me very well indeed.
Kev
PostPosted: Tue May 22, 2018 2:14 pm
Has thanked: 706 times
Been thanked: 2037 times
just be aware you have battery and tool restrictions as in older tools and batteries need to be compatable j&k knows all about it :thumbright:
to do with stars any yellow i think :lol:
For this message the author big-all has received gratitude : Kev888
PostPosted: Tue May 22, 2018 6:45 pm
Thanks, I'd run across the makstar thing but hadn't fully realised the implication. :thumbright:
I'm unlikely to go for small batteries or old tools, but well worth keeping in mind just in case.
Kev
PostPosted: Tue May 22, 2018 9:42 pm
Old School Chippie
It isn't just lack of power which is the issue - cordless means that I'm not dependent on sometimes flaky site electrics (and idiots who think it's OK to plug 10 tools into one 5kVA transformer running off a 13 Amp socket when you aren't looking) as well as neatly sidestepping PAT test issues (other than the chargers). More a site thing, I know.
Older isn't an issue - battery size is, TBH there can't be that many of the older 3 and 4 Amp batteries out there, can there? I say that because the Makstars started appearing 4 or so years back whilst the protection circuitry started appearing in tools back on "B" series days (for example my 7 year old BTD145 impact driver has it)
