It is currently Fri Feb 22, 2019 10:40 pm
PostPosted: Thu May 17, 2018 6:04 pm
Has thanked: 4 times
Hi
if someone could please help that would be great.
I was trying to install the following item which i got off Amazon
' 20m Professional Copper RG59 BNC Video and DC Power CCTV Cable '
i slipped off the ladder and pulled the cord instinctivley (rank amateur diy), i sheared off the BNC and power connectors from the part of the cable i was meant to connect to my DVR, i have looked online and seen that replacing the BNC connector is fairly easy, the power part is baffling me, i have exposed the cable to find a exposed copper wire and a white cable, will i be able to repair this cable or not as i have already layed the cable all through my loft.
If its possible can someone please advise if i can rescue my humongous mess up ?
kind regards in advance
PostPosted: Thu May 17, 2018 6:23 pm
this is a picture of the damaged cable
File comment: This is a image of the damaged cable
PostPosted: Thu May 17, 2018 6:26 pm
Has thanked: 62 times
Been thanked: 650 times
if you pulled it, you more than likely damaged the cable not just the plugs, imho replace the cable
bnc plugs arent that easy especially if its a compression type, the jack plug will need to be soldered on once you work out what is pos and neg
edit. that's not a great quality cable
For this message the author Bob225 has received gratitude : rkgooner89
PostPosted: Thu May 17, 2018 6:45 pm
Has thanked: 349 times
Been thanked: 1825 times
If it is a single cable with coax and power running up separately then I agree with Bob225 - unless you have experience with cables and the BNC connector then you will never get a satisfactory fix.
PostPosted: Thu May 17, 2018 7:21 pm
Has thanked: 67 times
Been thanked: 148 times
These are cheap to buy now so just replace.
For this message the author lockie has received gratitude : rkgooner89
PostPosted: Thu May 17, 2018 9:42 pm
Has thanked: 40 times
Been thanked: 1429 times
I guess you paid around £12+ for it?
new one on ebay less than £10 Click here
You could solder it, but if you knew how to solder it you would not be asking on here.
For this message the author someone-else has received gratitude : rkgooner89
PostPosted: Fri May 18, 2018 7:46 am
Thank you everyone for your advice,
looks like i will go down the route of buying a new one and then laying it (carefully) it was quite clearly my mess up,
just was confused with what i found under the sheath of the power cable, no red or black wires, just a white wire and exposed copper. :dunno:
cheers to you all :thumbleft:
PostPosted: Fri May 18, 2018 2:02 pm
Its a common on cheaper cables they wrap the cable to insulate it then its put wrapped with the coax
The problem is these type of cables suffer from voltage drop and signal degradation even over 5 meters
The proper shotgun cables avoid this issue (2 cables side by side in a figure 8 pattern)
