It is currently Sat Feb 16, 2019 6:25 pm
PostPosted: Tue May 15, 2018 2:03 pm
Has thanked: 36 times
Been thanked: 10 times
Hi
I have some display equipment which I need to disassemble. Unfortunately it's built very awkwardly. They seem to have used some sort of specialist tool which a regular tool does not have a clearance to access.
I need to weld just 5mm tip of a secure torx bit to a flat metal piece like a philips screwdriver tip at a right angle in order to loosen this bolt. You can see in this image attached that I have tried to shave off a bit of the torx key, but the amount removed is far too much and comprimises the strength of the key - it bends before it would move the bolt at all.
I do not have a welder, was hoping for some ideas on how to adapt a tool for this.
PostPosted: Tue May 15, 2018 2:33 pm
Has thanked: 1205 times
Been thanked: 1095 times
Get a piece of flat mild steel bar of suitable length. Something like 20 X 3mm, but anything will do.
Cut the end off the torx bit at suitable length.
Drill a hole a bit smaller than the torx "splines" in the flat bar.
Press the piece of torx bit into the hole in the steel bar using the vice, and a suitable size nut behind.
If you have to get it welded just grind it flat and get somebody to put a spot of weld on it from the back. Easy job, local garage will do it.
PostPosted: Tue May 15, 2018 3:26 pm
Has thanked: 61 times
Been thanked: 645 times
What size torx ? whats wrong with a standard torx key ?
eg. https://www.ebay.co.uk/itm/Draper-Extra ... SwrhhaE6tE
