It is currently Fri Feb 22, 2019 12:12 am
 Post subject: Connecting a PIR light
PostPosted: Sat May 12, 2018 5:00 pm
Has thanked: 890 times
Been thanked: 385 times
I need to connect a PIR light to the rear of my house to shine on to my back garden. Can I take the feed from a socket using 1.5mm T&E or does it need to be 2.5mm T&E?
PostPosted: Sat May 12, 2018 5:12 pm
Has thanked: 40 times
Been thanked: 1429 times
You have to use the same size cable that is already there. (2.5) This is because if there is a fault the weakest link fails first, which would be 1.5mm cable (if you used it)
How ever, what you should do, is to fit a 2.5mm cable feeding a fused connection unit, then you can use 1.5mm cable to the light. (you could also use 1mm cable)
If you get one like Image since it has an inbuilt switch it will make life easier.
I would also suggest two lights might be better, as one light is often mounted high up, which then lights up next door, the garden either side..........
For this message the author someone-else has received gratitude : Argyll
