It is currently Tue Feb 19, 2019 1:03 pm
Post new topic Reply to topic  [ 19 posts ]  Go to page 1, 2  Next
 Post subject: how to power my coolbox
PostPosted: Fri May 11, 2018 4:54 pm
Has thanked: 6 times
i have a connabride coolbox model tristar KB-7224.it runs from a 12v dc plug;unfortunetly i dont own a car.itried ebay for a converter but am told the converter for such a plug,wont power a coolbox.i need to run the coolbox from the mains.any ideas please?
PostPosted: Fri May 11, 2018 5:04 pm
Has thanked: 1531 times
Been thanked: 3851 times
:welcomeuhm:
There should be a rating plate on the coolbox, probably on the back. post the details here and we should be able to point you in the right direction...
For this message the author wine~o has received gratitude : sprocket24
PostPosted: Fri May 11, 2018 5:25 pm
hi,thanks for your reply;the following information is from the instruction manual.rated voltage;AC220-240v 50Hz .the socket must be at least 16A or 10A slow protected
the instructions state that when operating with a battery;60w-5.5 amps.
PostPosted: Fri May 11, 2018 5:33 pm
sprocket24 wrote:
hi,thaanks for your reply;the following information is from the instruction manual.rated voltage;AC220-240v 50Hz .the socket must be at least 16A or 10A slow protected
That can't be right. If your first post is correct
:scratch:
PostPosted: Fri May 11, 2018 5:53 pm
:scratch:
ive copied the manual directions.wheres your discrepancy please?
PostPosted: Fri May 11, 2018 6:18 pm
12 volt Direct current in your first post (from an accessory socket in a car) Vs. 220/240 volt Alternating current from your manual.
PostPosted: Fri May 11, 2018 6:28 pm
thatll be 12v DC
PostPosted: Fri May 11, 2018 6:33 pm
sprocket24 wrote:
thatll be 12v DC
yes but at what current? hence why I asked for the rating plate info. might be inside the coolbox or on the back.
PostPosted: Fri May 11, 2018 7:00 pm
Has thanked: 40 times
Been thanked: 1429 times
sprocket24, sorry to tell you but, those cool boxes are clever, but a waste of time. Read the instructions and does it say something like "It will maintain a temperature of * Degrees lower than ambient air temperature"
I had one, and the theory is great, but in practice it only gets cool, not "freezing" and if you have to plug it into the mains, why not buy a small fridge?
If you still want to (waste your money) try it, get the 10A one from here
Its better to have a bigger powersupply than a smaller one, since it will only draw what it needs.
For this message the author someone-else has received thanks - 2: sprocket24, wine~o
PostPosted: Fri May 11, 2018 7:04 pm
Thanks for editing your post after I had replied.
As they say on Dragons Den. I'm out.
PostPosted: Fri May 11, 2018 8:29 pm
NOT GUILTY!
And I am asking what part am I supposed to have edited?
For what its worth, that post took a bit longer than most as I wanted it to link directly to the power supply, not to a drop down menu, so I tried a couple of times before I clicked the SUBMIT button, and besides, if I had edited it after you posted, would you not see the tiny text that says edited by and the time?
Besides, what would be the point of editing it? all I did was copy / paste what you both said then added my opinion.
PostPosted: Fri May 11, 2018 9:03 pm
Has thanked: 318 times
Been thanked: 962 times
NOT GUILTY!
Chill out SE... I'm pretty sure that Wine O was referring to the OP and not you :thumbleft:
For this message the author Razor has received gratitude : someone-else
PostPosted: Fri May 11, 2018 10:56 pm
Has thanked: 349 times
Been thanked: 1823 times
Any AC mains-to12V DC power pack rated at over 8A will work. But 'cool boxes' have very poor insulation (if any) and I've had better performance from a cardboard box lined with thick polystyrene sheets (old packaging) and a couple of freezer blocks (those blue things) stuffed in them. Kept stuff from defrosting (fully) for over 48 hours. Once the stuff defrosted it kept another 2 days before it was getting too warm to be safe.
Cool boxes are a waste of money imho.
PostPosted: Fri May 11, 2018 10:57 pm
:thumbleft:
PostPosted: Sat May 12, 2018 6:59 am
Has thanked: 45 times
Been thanked: 730 times
I quite like my coolbox for summer travel. Handy way of keeping things cold in hotel rooms etc.
