It is currently Sat May 25, 2019 8:19 am
PostPosted: Fri May 11, 2018 10:08 am
Has thanked: 45 times
Been thanked: 759 times
Upstairs bathroom sink drains very slowly. Nothing blocking the plug hole, being a bathroom it does get biofilm buildup around the drain but I clean this regularly, looking down into the trap now it is spotless white pipe.
Plunging seems to make a difference but only for a few days and then it slows again.
Any ideas before I start stripping out the waste pipe?
PostPosted: Fri May 11, 2018 10:26 am
Has thanked: 710 times
Been thanked: 2043 times
do you have people using the sink with long hair ??
PostPosted: Fri May 11, 2018 10:44 am
Has thanked: 349 times
Been thanked: 1829 times
Greasy gunge - usually non-dissolved soapy products. I'm guessing your trap isn't the standard u-bend but one of those 'compact' straight versions???
I use the palm of my hand to give it a 'plunge' every couple of days and it tends to keep it clear.
PostPosted: Fri May 11, 2018 11:30 am
Not particularly long. A strainer is used to trap hair. Some does make it to the gully but I clear that often too.
No it's a standard U bend and it's perfectly clean at the trap end. I guess the problem must be further down the line.
PostPosted: Fri May 11, 2018 2:03 pm
Has thanked: 1561 times
Been thanked: 3914 times
You could try caustic soda, careful though as it needs handling with caution.
(do not confuse caustic soda with soda flakes)
PostPosted: Fri May 11, 2018 2:17 pm
I have plenty of caustic soda on hand, will give that a try.
PostPosted: Fri May 11, 2018 10:56 pm
Has thanked: 41 times
Been thanked: 1480 times
Its a bit late now, but DO READ THE INSTRUCTIONS.
You mix it in a bucket of HOT water then pour it down said plug hole. If you pour it in cold, it can set like concrete. (No, it wasn't me, but I lent him a drill to drill holes through it, and it worked)
PostPosted: Sat May 12, 2018 7:00 am
NOOOO you never add caustic soda to HOT water! ::b ::b
PostPosted: Sat May 12, 2018 7:24 am
Has thanked: 327 times
Been thanked: 975 times
You can add it slowly to hot water but you can't add hot water to caustic soda.
Used tons of it on 2 stroke exhaust when I was a lad
