It is currently Sun Apr 21, 2019 9:58 pm
PostPosted: Mon May 07, 2018 9:09 pm
Has thanked: 16 times
Been thanked: 1 times
I have a celling light with 5 or 6 LED bulbs fitted. Just noticed they are glowing dimly but the light switch is turned off.
If I trip the cct breaker at the fuse box for the lighting cct they stop glowing.
If I remove one of the LED bulbs and fit a halogen bulb they stop glowing.
My first thought is that there is current leakage but I cannot convince myself that is correct but that's still all I can think of.
what are your thoughts?
thank you
glassescase
PostPosted: Mon May 07, 2018 9:23 pm
Has thanked: 709 times
Been thanked: 2041 times
its induced current with another circiut next to the wires powering somthing causing the induction
with leds working on say 3w as little as 0.5w will cause them to glow
works in a similar way to your rechargeable toothbrush with no metal to metal contact
PostPosted: Tue May 08, 2018 8:23 am
thanks big-all, sort of what I was thinking. how the heck do I trace and solve this? Why do the LED's go off if I replace 1 with a Halogen bulb?
If I have other lighting cables at the same switch as it is a 3 gang switch I'm a bit stumped on what to do.
Is replacing cables the answer?
glassesase
PostPosted: Tue May 08, 2018 9:26 am
its not actually a problem its not a fault to find
its actually virtually no current
you could try another make off led bulb that may need a greater current to "flicker" with
you could replace one with another sort[incandesent/low energy ] to stop the ghostly effect but at the extra consumption
its just cables running along side they may have a direct connection or no connection at all think along the lines off static but without the capacity to store the energy
as an aside
if we assume about 14p per kwh or unit off electricity
and your bulb or tv or what ever is on for an average 10 hrs a day
for every 1watt consumed you will use 50p a year so iff you replace a 3w led with a 7w le bulb you will consume an extra £2 a year [4wx50p]
For this message the author big-all has received gratitude : glassescase
PostPosted: Tue May 08, 2018 9:50 am
thank you. what do you think about leaving 1 halogen bulb in, will that suffice or will there still be a current draw.....just not enough to make the LED's glow?
glassescase
PostPosted: Tue May 08, 2018 9:59 am
its minute amounts off current if you have different sorts off leds mix and match and leave the glowing ones where they wont bother you :lol:
but any low energy bulb will use less current than a halogen but solve the problem
PostPosted: Tue May 08, 2018 6:08 pm
big-all, why do the LED's in the light fitting stop glowing when I replace just 1 with a halogen bulb?
glassescase
PostPosted: Tue May 08, 2018 6:24 pm
Has thanked: 41 times
Been thanked: 1470 times
As big-all said the lights are glowing because there is an induced current / voltage in the cable. (It often happens on the light you have on the landing)
When you add a "normal" lamp there is so little current / voltage that it can not even make this lamp glow. (Although it tries) because the induced current / voltage is trying to light the "normal" lamp, there is (if you will) none left for the other lamps, so they do not glow.
For this message the author someone-else has received gratitude : glassescase
PostPosted: Tue May 08, 2018 9:10 pm
thank you someone-else.
Now I understand.
As its a bedroom light I'll leave the halogen bulb in place.
thanks again someone-else and big-all
glassescase
PostPosted: Wed May 09, 2018 7:01 am
Has thanked: 65 times
Been thanked: 560 times
In theory any bulb which states suitable for dimming should have a leak off resistor built in, so the very small amount needed to work the dimmer (or any other electronic switch without a neutral) will not cause the lamp to light.
However some makes leak off more than others, one can use a interference capacitor same as found in electric drills and the like to leak off a little more to stop lamps glowing, however in most cases all that is needed is select another make, normally the cheaper the better.
For this message the author ericmark has received gratitude : glassescase
