It is currently Fri Apr 19, 2019 9:34 am
 Post subject: Electric Oven Hob wiring
PostPosted: Fri Apr 13, 2018 1:00 pm
Has thanked: 1 times
Hi all,
I'm looking for some advice on replacing my built-in oven and hob, on removing the old oven and hob I find two separate 4mm flat grey wiring, not 6mm as I was expecting, and on looking behind the outlets it's 4mm flat grey wire up to the switch. Now for the question, should I fit 4mm wiring from the first out on the wall to the oven and then to the hob and then back to the second outlet on the wall. (drawing two)
I have attached a crude drawing to show a bit better than my explanation. The first picture number one is as the cooker was wired with 4mm grey flat cable, the second picture is as I thought it should be wired to maintain the circuit ring. Or is it ok just to wire it as original, one wire to the oven and then one to the hob (drawing one)?
Because there are two separated units.
Many thanks in advance for any advice Mike.
PostPosted: Fri Apr 13, 2018 2:38 pm
Approved Electrician
Has thanked: 174 times
Been thanked: 594 times
:welcomeuhm:
Are the two appliances on the same circuit?
PostPosted: Fri Apr 13, 2018 3:35 pm
Yes, the appliances are on the same circuit. one cooker main switch and one 32amp trip fuse
PostPosted: Fri Apr 13, 2018 3:40 pm
There is no need to make this into a ring. In fact if you did you would need to switch off both switches to turn the appliances off.
You have a perfectly normal radial circuit.
For this message the author OnlyMe has received gratitude : Mike GF
PostPosted: Fri Apr 13, 2018 4:16 pm
That's great you have put my mind at rest, I will just wire it up as it was. I'm glad I found this forum :thumbright: Thanks for your help OnlyMe.
