It is currently Tue Feb 19, 2019 9:55 pm
Post new topic Reply to topic  [ 1 post ]
PostPosted: Thu Apr 12, 2018 9:05 am
Hi All,
So our thermostat has recently died and I had said for a while that I wanted to change to Hive, so it seemed like the best opportunity.
My old system consisted of:
Drayton LP241 programmer
Drayton RTS1 Thermostat
The boiler is a Potterton Suprima 50l
I have replaced the programmer with the Hive receiver using the exact same wiring in the same slots and disconnected the thermostat.
Everything is connected and I can set the heating on the on the app and the Hive thermostat.
I have a separate cold water tank in the loft and a hot water tank in a closet. I have set the receiver to gravity fed mode.
When I press the boost the lights on the receiver come on and I hear the boiler start up, a few seconds later the boiler flame/light comes on, looks like everything is working fine. A few seconds later the boiler flame/light goes off and a few seconds after that the noise from the boiler goes off. The lights are all still on the receiver.
5 minutes or so later the boiler repeats the above process, going on for a few seconds then back off.
The only thing that isn't the same as the old system is the old thermostat is not connecting and the wiring (neutral, live and call for heating) are no longer connected to anything.
Please can you help with this matter?
Kind regards
Rob
File comment: Original Wiring
Users browsing this forum: D Hailsham and 1 guest
