It is currently Wed Jan 23, 2019 8:10 pm
 Post subject: Bosch oven HBN3318B
PostPosted: Sat Apr 07, 2018 5:22 pm
All...need a bit of help. I have purchased a bosch oven that needs to be hard wired on the oven part. but I'm not sure what type of power cord /cable connector i need to make the oven work so any pointers would be appreciated. Pic of the back of the oven is attached. Many thanks. Nawaz
 Post subject: Re: Bosch oven HBN3318B
PostPosted: Sat Apr 07, 2018 5:34 pm
Has thanked: 39 times
Been thanked: 1415 times
What rating is the oven?
......and what do you intend to connect the other end of the cable to?
PostPosted: Sat Apr 07, 2018 7:48 pm
Thanks, these are specs from the installation sheet..
Electrical connection rating (W) : 2350
Current (A) : 13
Voltage (V) : 220-240
Frequency (Hz) : 50; 60
Plug type : fixed connection, no plug
I was planning connecting the other end of the cable to a standard 13A socket (the socket my old electric oven was plugged into). I thought it would be simple job of taking the old one out and putting the new one in - but unfortunately Bosch had other ideas about making connecting an oven an easy task!
Nawaz
PostPosted: Sat Apr 07, 2018 7:57 pm
Has thanked: 1509 times
Been thanked: 3840 times
2350 W should be pluggable (if that's a word). However MI's always should be followed. A 13 Amp switched fused unit fitted down t one of these https://www.diy.com/departments/crabtre ... icamp=recs
(picked at random) and 2.5mm sq twin and earth should be more than man enough. Unless the MI's say you need a different type of cable.
(MI's = Manufacturers Instructions)
PostPosted: Sun Apr 08, 2018 1:07 am
thanks for the reply - already have the switched fused unit & wall socket fitted. I can't work out what type of connector i need to buy and where from so i can connect the other end of the cable to the oven unit.
Nawaz
PostPosted: Sun Apr 08, 2018 8:11 am
Approved Electrician
Has thanked: 168 times
Been thanked: 582 times
Use 1.5mm 3 core flex and a 13A plug.
PostPosted: Sun Apr 08, 2018 8:29 am
Yes, understood - how is the 1.5mm 3 core flex cable attached to oven.
Does it have to be soldered on? Or can I purchase a type of connector where I can screw the 3 cable ends in and attach to oven (this is my preference).
PostPosted: Sun Apr 08, 2018 8:34 am
You don't need a connector. Those "studs" are the connectors. You loosen (don't undo completely) the screw, lift up the little plate behind the screw, poke the wire in under the plate*, tighten the screw up and give the wire a tug. If it comes out you have done it wrong.
You obviously strip the end of the wire about 1cm.
As only me says you need 1.5mm flex and a plugtop.
I would suggest This flex (You can buy just 2m) and this plug
You must have a decent plug if you don't it will over heat
PostPosted: Sun Apr 08, 2018 4:43 pm
In summary i was making something more complicated then it needed to be. All fitted and working well so thanks for the reply - much appreciated.
Nawaz
