It is currently Tue Apr 23, 2019 5:13 am
PostPosted: Sat Apr 07, 2018 3:35 pm
Has thanked: 65 times
Been thanked: 560 times
I tend to use Screwfix a lot for parts, it is simply handy to where I live, so when I want items I tend to look there first. However with 12 volt LED lighting there advice seems to be flawed.
ImageThis is a good example, in the question and answers it asks "does the transformer need to be upgraded for this product?" the answer
Quote:
Hello Colmartin,
When installing these products you will need to use an LED voltage Driver. This can be found under the following links:
http://www.screwfix.com/p/halolite-led- ... 1-9w/66599
http://www.screwfix.com/p/halolite-led- ... -16w/85503
Thank you for using Q&A
I could not believe my eyes, clearly the constant current driver (66599) is completely unsuitable, and even the constant voltage driver (85503) has a DC output, but the picture shows 50Hz/60Hz so clearly designed for AC not DC. Avert here
PostPosted: Sat Apr 07, 2018 3:51 pm
Approved Electrician
Has thanked: 175 times
Been thanked: 594 times
I would expect the lamps to work with either AC or DC. The CC driver is of course not suitable.
PostPosted: Sat Apr 07, 2018 11:16 pm
Likely be it DC, 50/60 Hz or MHz, as long as the supply can regulate at such a low output and it is 12 volt RMS there will be no problem. How when the product is clearly marked 50/60 Hz then not actually recommending a toroidal transformer is wrong.
