It is currently Sat Jan 19, 2019 12:52 pm
PostPosted: Mon Apr 02, 2018 8:03 pm
Hello - see image - these are small solid lumps not bubbles.
The wall originally had orange emulsion on lining paper, this was covered in white matt emulsion to take the colour down. When this had dried (a few days). Two layers of blue matt emulsion (Homebase own brand) were added without any problems. It needed a third coat to deal with a bit of unevenness in the coverage. That is when the spots appeared. They appear a few seconds after application. I have tried with a brush, pad, and two different types of roller, and in different parts of the room - makes no difference. The previous coats had been left to dry for about 18 hours.
Has anyone any idea why this is happening?
Thanks in advance for any help.
File comment: paint spots
PostPosted: Mon Apr 02, 2018 8:27 pm
Has thanked: 755 times
Been thanked: 843 times
:welcomeuhm: Have you tried breaking one of those bubble things to see what is inside? If they just appear they cannot be something put on by your most recent coat of paint or you would see the lumps being deposited on the wall, so they are bubbles and they can be tough because they can be made by multiple layers of paint.
The chances are that one of the previous coats of paint has not adhered well. It could be because the wall was dirty or contaminated with who knows what, or the paint was cheap cheap sh1te that could not stick on anything. Anyhoo, a subsequent coat of paint hydrates the paint already on teh wall and where there is a weakness you get a bubble. If you scrape a couple of the bigger bubbles you will see what you got underneath ... it could be the wallpaper, or the orange paint or the white paint or one of your blue coats. All the bubbles are near the seam so it might be old adhesive that was on the wall paper.
You need to improve your technique and use a medium pile roller sleeve (Hamiltons perfection range). Your painting shows too many short strokes and uneven orange peel. A good sleeve would allow you to carry more paint and get a more even coverage with at least an even orange peel. You still need another 1 or 2 coats of paint given the shade I see in your photo.
The only cure there is to scrape off the lumps and sand them down. There is a danger they will reappear when you apply another coat of paint in which case you have to consider using Zinsser Peel-Stop
PS. I had your problem over unprimed porous fillers. What is white paint you used and was it new paint?
Other than that we will all say in one voice "retail paints suck" :wav:
PostPosted: Mon Apr 02, 2018 9:38 pm
The only cure there is to scrape off the lumps and sand them down. There is a danger they will reappear when you apply another coat of paint in which case you have to consider using http://www.zinsseruk.com/product/peel-stop/
Hello, thanks for replying. The coverage in the picture is a bit sh1te because I'd already had a scrape and a wipe of some of the previous spots, added a bit more paint, wiped that away etc - so wiped away a bit of the other coats. The photo also shows the blue as a lot lighter than it really is. Other bits of the room have more even coverage, are in the middle of the paper, and some of the spots appear as I'm painting, most appear after about 15-30 seconds. When I've scraped them off the white emulsion appears. The last sleeve I used was a Harris 'Tiger Stripe'. The white paint was new matt emulsion.
PostPosted: Mon Apr 02, 2018 10:02 pm
Sometimes, bubbles like this shrink back .... maybe let them dry first. It sounds like you will need the zinsser stuff I mentioned above or a lot of scrapping and sanding which is not ideal over lining paper.
PS. Does the white paint stay on the wall or does it come off with the bubbles? Do you see orange underneath it?
PostPosted: Mon Apr 02, 2018 10:40 pm
The white stays on. The bubbles are still there after about 8 hours, so I don't think they're going away of their own accord! I pressed a few with my finger and they almost disappeared so you barely see them, but I don't fancy doing that with a whole room :-)
Maybe I'll just stick a load of pictures up to hide it. It's in my bedroom, so doesn't really get visitors :-p
PostPosted: Tue Apr 03, 2018 6:31 pm
Has thanked: 1509 times
Been thanked: 3834 times
Was the emulsion thoroughly stirred before application ?
