It is currently Fri Feb 22, 2019 4:55 am
PostPosted: Fri Mar 30, 2018 8:39 am
Good morning, I'm going to be putting up some wood cladding (spruce) and would like some advice on painting it. Do I need to prepare the wood at all before painting? And is there any type of paint I should use/avoid? I. E is water based paint OK, or will this cause the wood to warp?
Many thanks
PostPosted: Fri Mar 30, 2018 9:50 am
Has thanked: 643 times
Been thanked: 1816 times
The biggest issue is shrinking and warping. Assuming this is indoors I would leave it to acclimatise for a few weeks in the area you are cladding and then paint both sides and edges with a good primer to seal it up before you fix in position. I would even put an undercoat on as well as any shrinking will expose the tongue so you want it Well covered. Secret nail through the tongue as a fixing method to minimise nail heads showing.
If this is exterior get Marley Eternit instead of spruce.
Painting with BIN
PostPosted: Sun Apr 01, 2018 12:28 pm
Has thanked: 19 times
Been thanked: 8 times
Agreed- prime first including knotting on face side & acclimatise - I would even suggest first coat of finish.
An alternative is green mdf in TVG sheets- again prime first and if you pin through the grooves, easier to hide when finishing.
PostPosted: Tue Apr 03, 2018 10:09 am
Brilliant thanks for taking the time to reply.
Just to check, once primed, can any type of paint be used, or does it specifically have to be wood paint?
PostPosted: Tue Apr 03, 2018 10:17 am
It depends on what you want as a finish really. An acrylic paint is easy to roll on and will give a durable finish. Avoid emulsion, it is not the best for wood.
Painting with BIN
PostPosted: Tue Apr 03, 2018 10:35 am
And would you recommend this for the primer?
https://www.screwfix.com/p/dulux-trade-trade-quick-drying-wood-primer-undercoat-1ltr/24583?tc=FB5&ds_kid=92700030933329415&ds_rl=1245250&ds_rl=1249484&gclid=Cj0KCQjwzIzWBRDnARIsAAkc8hEIkgPE9OrcFYrZe8fKvkLnI2rg26wJzcLnMMb3YeCBQ0-0WLrfEPMaAp1uEALw_wcB&gclsrc=aw.ds&dclid=CNyq_LrmndoCFQgx0wodpHEOUg
PostPosted: Tue Apr 03, 2018 11:20 am
As good as any :thumbright:
Painting with BIN
PostPosted: Tue Apr 03, 2018 11:24 am
Thanks again! I'm sure I'll be back once I start the job....
PostPosted: Tue Apr 03, 2018 11:44 am
Good luck. Have a look at this as it might be useful https://www.youtube.com/watch?v=f64qFTnoIyI :thumbright:
Painting with BIN
PostPosted: Tue Apr 03, 2018 6:31 pm
That's a great video, thanks, looking forward to getting started once the wood has climatised! I'll post a pic once done.... If it looks any good! :lol:
cron
