It is currently Thu Apr 25, 2019 3:20 am
Post new topic Reply to topic  [ 32 posts ]  Go to page 1, 2, 3  Next
 Post subject: Power Cord Help
PostPosted: Thu Mar 22, 2018 4:21 pm
Has thanked: 13 times
Hi all
I have recently purchased a second hand JVC X70 projector, unfortunately it did not come with a power cord. It was just to ask if anyone would be able to tell me the correct power cord I should get?
I have attached a picture showing the electrical information and power cord input on my projector.
Appreciate anyone's input
 Post subject: Re: Power Cord Help
PostPosted: Thu Mar 22, 2018 4:39 pm
Has thanked: 709 times
Been thanked: 2041 times
standard cord just make sure the fuse is the correct size in the plug at 3/5/7/10or13amp
For this message the author big-all has received gratitude : RadX
PostPosted: Thu Mar 22, 2018 5:12 pm
Hi thanks for your quick reply! Would something like this be ok/ standard cord?
https://www.amazon.co.uk/C2G-0-5m-Power-Cord-IEC320C13/dp/B002CZQ3G6/ref=pd_sim_147_8?_encoding=UTF8&refRID=2K763YSE4TSGT46ZR9BG&th=1
I think this has a 13 amp fuse and max current of 10 amps. The projector only says 1.4A so 10A sounds very high! Am i right in thinking the projector will only draw 1.4A at 240V and the rest of the available amps will not be used,?
PostPosted: Thu Mar 22, 2018 5:39 pm
Has thanked: 349 times
Been thanked: 1829 times
The fuse protects the cable, not the equipment. That lead (commonly called a 'kettle flex') is perfectly suited.
For this message the author kellys_eye has received gratitude : RadX
PostPosted: Thu Mar 22, 2018 5:42 pm
Has thanked: 1550 times
Been thanked: 3894 times
swap the fuse in the plug for 3 Amp.
PostPosted: Thu Mar 22, 2018 5:51 pm
Thank you! I found a cheaper one which i think i may go for instead :-)
https://www.amazon.co.uk/unbranded-RB-250-CABLE-MAINS-POWER-black/dp/B0011YI5II/ref=cm_cr_arp_d_product_sims?ie=UTF8
After a quick read about fuses i now know that the fuse should be only slightly higher than the current the device draws. Since the projector only draws about 2A i think this new power chord should be better as it is rated at 5A instead of 13A. Please let me know if this is a load of rubbish!
PostPosted: Thu Mar 22, 2018 5:54 pm
Hi wine~o seen this after i had just replied, so do you think a cable with a 3A fuse is what i should get instead of the 5A one?
Appreciate your thoughts
PostPosted: Thu Mar 22, 2018 6:18 pm
Has thanked: 41 times
Been thanked: 1470 times
as kellys_eye said, the fuse is to protect the cable, not the device at the other end, so in your case get which one you like but change the fuse to a 3A
You are also right with your statement of how much your projector will draw.
For this message the author someone-else has received gratitude : RadX
PostPosted: Thu Mar 22, 2018 7:21 pm
Ah ok thanks i think it is starting to make a bit of sense. The projector will draw roughly 2A at 240V from the mains, by changing the fuse to 3A i am making sure that the circuit will cut off at anything above 3A therefore stopping the high current reaching the device or burning the cable?
PostPosted: Thu Mar 22, 2018 7:35 pm
the only reason i mentioned other amperages is because you can use the lead off any old computer/kettle/tv you have lying about in the house as long as it fits and the fuse fitted is greater than 3amp :lol:
PostPosted: Thu Mar 22, 2018 9:31 pm
I think I will go for a cheapo kettle cord and then replace the fuse with a 3A one as suggested. Should only cost around £5 all in :-)
Thanks for all the input guys, I learned something about fuses today!
PostPosted: Thu Mar 22, 2018 9:53 pm
have you thought about using any old lead to check the projector works before investing in a new lead :dunno:
PostPosted: Thu Mar 22, 2018 10:30 pm
I did think about that before i posted on here, but didn't know if i would blow up the projector by using the wrong cord :lol:
Not sure if i have any 3A or even 5A kettle cords, but i will have a look tomorrow. Think i may have one from the TV which i guess would work well for testing purposes. Either way i think i will have to buy a new one as i doubt any i have are long enough, but for £5 i wont complain :mrgreen:
PostPosted: Thu Mar 22, 2018 10:34 pm
it is irrelivent what the cord is if it fits it will work the ah as in 13a is the fuel tank so makes no difference provided its the minimum required or more it will work
PostPosted: Thu Mar 22, 2018 10:53 pm
Thanks i think i understand that, for normal use it will make no difference as the projector will only draw what is needed, as as long as it is above the minimum it will work. But it's still safer to use with a 3A fuse, right? :oops:
