It is currently Mon Jan 21, 2019 6:18 am
PostPosted: Sun Feb 25, 2018 6:16 pm
Has thanked: 2 times
Been thanked: 1 times
hi all,
my question is similar to this post:
fitting-kitchen-tap-t92907.html
but i have a slight different issue.
my copper pipes run from the old tap, half way is an isolating valve, it continues where it bends and carries on to the mains
the new replacement tap flexi tail connectors are too long. in fact, in runs down the entire length of the copper pipe, past the iso valve and ends just before the bend
now due to a very small leak, the elbow joint has decayed and i will need to remove it and replace it. i have already got a compression elbow
what do i do in this case where the flexi tails are too long.
also in regards to isolating valve will standard suffice or do i need a bore one?
many thanks in advance
finest! :hello2:
PostPosted: Sun Feb 25, 2018 6:25 pm
Mr. Grumpy
Has thanked: 31 times
Been thanked: 116 times
Can't you just cut the pipe further down below the iso value and attached new isolation valves lower down, (if still accessible ).
Flexible tap connectors can bend no issue.
I would use full bore iso valves in a kitchen tap, bathroom tap no (if on the mains) Depends on your water pressure of course
PostPosted: Sun Feb 25, 2018 6:45 pm
Has thanked: 1509 times
Been thanked: 3834 times
how long are the supplied tails ??
PostPosted: Sun Feb 25, 2018 7:23 pm
hi all
thanks for your response. I've attempted to attach some photos
first photo:
1) where the flexi hose screws into tap
2) isolation valve
3) elbow joint
second photo is more of a close up
hope this helps explain further.
PostPosted: Sun Feb 25, 2018 7:45 pm
Has thanked: 3 times
Been thanked: 18 times
Either:
1. Cut the copper pipe far down so the supplied hoses fit.
2. (Preferred) Get different flexi hoses- they come in variety of lengths- those look bloody massive! Then cut further up the copper, make for a neater install.
PostPosted: Sun Feb 25, 2018 9:27 pm
columbiers wrote:
Either:
yeah, I been looking for shorter hose length. apparently 300m is the shortest. the one in the photo is 400mm, not sure if they come shorter than that. it may be the only option though, thinking about it, get the 300mm and work with it
thanks
PostPosted: Sun Feb 25, 2018 9:33 pm
johnny, no issue with water pressure, the ones on there already look like standard ISO valves. would you still advise bore?
PostPosted: Sun Feb 25, 2018 9:53 pm
You can get shorter ones too, 150mm
PostPosted: Sun Feb 25, 2018 10:04 pm
the only ones i saw 150mm did not have the 10mm tap connector which screws into the actual tap. unless you can provide a link..
PostPosted: Sun Feb 25, 2018 10:27 pm
Ah, didn't see it was m10 at the tap. Do the 300,should give the room you need
PostPosted: Sun Feb 25, 2018 11:59 pm
Mr. Grumpy
I don't see any issues with cutting the pipe and moving or adding in two new isolation valves. You mention you have to replace the elbow anyway. It will take 30mins max.
I like full bore in the kitchen but it narrows down to 10mm at the tap inlet anyway it will make practically no difference in flow rate. I would just get whatever is convenient.
It depends if you have a pipe cutter, ptfe tape, spare olives etc. Easiest was out is as others say, just replace with 150mm pipe. Looking at the picture I'd say 300mm won't have any major issues, just look rather clumsy. Best measure it
