It is currently Sat Feb 16, 2019 1:19 am
PostPosted: Wed Feb 14, 2018 2:16 pm
Has thanked: 1 times
Hi everyone,
After doing some decorating recently I decided to replace a rusty radiator.
Now the radiator is fitted, I’ve noticed some things that are making me feel uneasy. I’m not sure if it’s due to the radiator being slightly wider, or the fitting on the pipe has always been slightly crooked. I’ve attached some images, as you can see the ‘up/down’ pipe isn’t completely straight, but the fitting which joints to radiator valve is.
Is this a potential risk for a burst pipe/leak?
Thanks for the help.
PostPosted: Wed Feb 14, 2018 8:33 pm
Mr. Grumpy
Has thanked: 31 times
Been thanked: 116 times
I wouldn't worry, the joint is a compression joint which means that an internal brass ring is compressed tight in the pipe by the bottom nut to create a water seal, If there was an issue there would be a tiny bit of water seeping out (called weeping). These things don't go suddenly and flood everywhere.
Unless the pipe had a noticeable kink in it I wouldn't have any concerns at all (apart from the looks)
PostPosted: Thu Feb 15, 2018 8:20 am
Thanks for the reassurance Johnny, it's leak free after 24 hours so I'm now content it's a job 'well' done :wink:
