It is currently Sun Feb 17, 2019 5:51 am
 Post subject: knotting solution
PostPosted: Fri Feb 09, 2018 12:35 pm
Has thanked: 22 times
hi all, my first post here, i have stripped all my paint of with a heat gun. my question is do i need to use a knotting solution before
repainting. many thanks.
 Post subject: Re: knotting solution
PostPosted: Fri Feb 09, 2018 12:38 pm
Has thanked: 643 times
Been thanked: 1810 times
It is worth it as the knots are not absorbent and you may have stripped off the original seal :thumbright:
Painting with BIN
For this message the author dewaltdisney has received gratitude : trevdell
PostPosted: Fri Feb 09, 2018 10:53 pm
CLOSED ACCOUNT
Has thanked: 900 times
Been thanked: 764 times
If you're going to be repainting, why not use BIN as a primer? Shellac based, so will cover both bases.
Sent from my SM-G850F using Tapatalk
PostPosted: Sat Feb 10, 2018 6:49 am
thanks Fitzy never used BIN, it is solvent based so is it ok using water based gloss finish?
many thanks
PostPosted: Sat Feb 10, 2018 9:17 am
Yes, it is fine for water based paint over. It is a horrible paint to use and the first coat is streaky but comes good on the second coat. It depends what you have to hand and how many knots to treat. A 1 litre can of BIN is £20 in Screwfix whereas knotting sealer is around £8 a can.
Painting with BIN
PostPosted: Wed Feb 14, 2018 12:42 am
Has thanked: 221 times
Been thanked: 389 times
You can often get a small bottle of knotting for about 4 quid..but BIN will do the job, if there is a lot of sun on the door i'd be tempted to use knotting under the bin or at least BIN the first first.
For this message the author Have Brush Will Travel has received gratitude : trevdell
