It is currently Tue Mar 26, 2019 12:55 pm
 Post subject: Bathroom Extractor Fan
PostPosted: Mon Feb 05, 2018 8:55 am
Has thanked: 3 times
My bathroom currently has the light and extractor fan linked to one another, so to turn the extractor back on I have to turn the light on and off. It's already on its maximum time setting.
So a couple of questions:
Firstly, can they be disconnected from each other, and the fan changed to a pull cord/switch? Reason I ask this is because the main window in the bathroom does not open, but there is a skylight that does (does this count as an opening window?). Or would it contravene building regulations?
Secondly, could they be left connected to one another so every time the light turns on, the fan comes on, but if a fan with a humidistat was installed, it could also come on by itself without me having to intervene and turn the light on?
PostPosted: Mon Feb 05, 2018 6:05 pm
Approved Electrician
Has thanked: 170 times
Been thanked: 589 times
I see no reason why they should not be separated from each other as I would consider the skylight an opening window.
You are obviously smart enough to know when to turn the fan on and off - so go for it.
Just one helpful tip for you - use a pull cord with a neon indicator - that way you will know if the fan is turned on or if it's on it's timed overrun.
I would not recommend a humidistat fan.
PostPosted: Mon Feb 05, 2018 8:35 pm
Has thanked: 25 times
Been thanked: 115 times
Why wouldn't you recommend the humidistat fan.
I'm only asking because I've just replaced the (dead) timer fan in my bathroom with a timer/humidistat one.
I am not a pro.
PostPosted: Mon Feb 05, 2018 9:15 pm
I find that they are a bit random in their controls.
PostPosted: Tue Feb 06, 2018 8:50 am
Thanks OnlyMe, that was my belief on the window but just wanted to check, and is that the case with all humidistat fans?
PostPosted: Tue Feb 06, 2018 7:41 pm
I cannot recommend one that will work well
Each to their own on how they deal with bathroom humidity and smells. I have a separate pull cord for a timed fan in my bathroom.
