It is currently Sat Jan 19, 2019 11:33 pm
Post new topic Reply to topic  [ 26 posts ]  Go to page 1, 2  Next
 Post subject: Mitre Saw for DIY
PostPosted: Tue Jan 30, 2018 10:02 pm
Has thanked: 4 times
Hello,
I've used a mitre saw in the past, it was a £50 jobby from B&Q but it died on me and B&Q could not replace it as they were out of stock. I never got around to buying a relacement but I now find myself in need of another one. I have a large rotten decked area to replace, I want to build an additional deck and most importantly I need to build wheelchair access to our side door which will consist of a ramp and raised platform with railings. I will be reusing some scaffold boards for the supports of this platform so the saw needs to be able to cope with cutting 225mm.
I don't have a work bench so will also need some sort of stand for the mitre saw. I'm a bit bewildered by all the different mitre saws available. I want something reliable with readily available replacement blades. I guess the top end of my budget would be £200 but for what I want I'm not sure I need to be spending anywhere near that much?
Any advice greatly appreciated.
 Post subject: Re: Mitre Saw for DIY
PostPosted: Tue Jan 30, 2018 10:49 pm
I've come across the Titan TTB598MSW currently £94.99 at Screwfix. The 310mm cross cut is what's caught my eye, that would easily handle the scaffold boards I want to reuse. There's also a Titan YH-MS029A stand to go with it. at £49.99
Do they look ok?
PostPosted: Wed Jan 31, 2018 1:28 am
Has thanked: 698 times
Been thanked: 2014 times
as an aside
its a screwfix special so go to the worst reviews and give them far more weight as they control the feed back and will edit out most off the negative ones
For this message the author big-all has received gratitude : JollyRoger
PostPosted: Wed Jan 31, 2018 4:28 am
big-all wrote:
as an aside
Thanks for that, the bad reviews have put me right off especially as the guard seems to have a habit of shattering dramatically.
PostPosted: Wed Jan 31, 2018 8:31 am
i am not saying dont believe the good ones just remember they are selling there own products and control what reviews gets through :lol:
so put back in the balance they skew :wink:
PostPosted: Wed Jan 31, 2018 9:22 am
I've had the Metabo KGS 216 M or Metabo KGS 254 M recommended elsewhere. Bother are looking good. A little more than I was hoping to spend when I add in the stand to go with them. Any thoughts on those?
PostPosted: Wed Jan 31, 2018 9:42 am
afraid i only have dewalt saws so cant comment on other makes
although i have a 18v ryobi and used to have a 24v bosch blue
the dewalts are my go to saw with the light ryobi for small moldings
PostPosted: Wed Jan 31, 2018 5:09 pm
Has thanked: 1509 times
Been thanked: 3834 times
I've got this one https://www.screwfix.com/p/evolution-ra ... 240v/60839
Which is just under a ton. Once set up correctly it's more than accurate enough (carpenters on here may disagree :mrgreen: )
It's an outgoing model and has been replaced by this https://www.screwfix.com/p/evolution-r2 ... 230v/2965v
Which has good reviews and cuts to 230mm on a straight cut.
That leaves you a few quid for a saw stand I have this one https://www.screwfix.com/p/titan-yh-ms0 ... tand/15762
Which is more than man enough for a handyman and better than evolutions own IMHO.
For this message the author wine~o has received gratitude : JollyRoger
PostPosted: Wed Jan 31, 2018 5:28 pm
Has thanked: 60 times
Been thanked: 625 times
You cant go far wrong with a Evolution Rage 3 - there are a few threads on here, there a very capable saw if you set them up correctly
I have the 255mm Rage 3 - no issue apart mine being a early one, so I did the guard mech upgrade what I got directly from evolution
For this message the author Bob225 has received gratitude : JollyRoger
PostPosted: Wed Jan 31, 2018 5:37 pm
Thanks guys, I have been looking at a Rage 3 today, this one:
https://www.toolstop.co.uk/evolution-rage-3-tct-multipurpose-sliding-mitre-saw-255mm-10-inch-240v-p13994
PostPosted: Wed Jan 31, 2018 6:41 pm
Has thanked: 408 times
Been thanked: 1483 times
https://www.toolstop.co.uk/evolution-ra ... 40v-p13994
I'd probably look at the Metabo, albeit it does have slightly less capacity for thickness of timber.(Three year warranty on all Metabo tools if you register them on-line).
https://www.toolstop.co.uk/metabo-kgs21 ... 40v-p72062
PostPosted: Thu Feb 01, 2018 12:45 pm
Mr. Grumpy
Has thanked: 31 times
Been thanked: 116 times
I wouldn't go too cheap on a sliding mitre saw. I bought an erbaurer but in hindsight wasn't a good buy. Problem with reviews is that people often review a product prematurely. By the time you are ready to review a product and thousands of cuts , the product is no longer in stock, has been updated etc.
Mine is OK but too much play in both bevel angles, laser broke, dust bag fell apart (was of little use anyway), clamps won't tightened down as screw slot material too soft and extension rods too thin.
PostPosted: Thu Feb 01, 2018 12:51 pm
Has thanked: 875 times
Been thanked: 378 times
I have the 254 version. A very good machine but quite heavy if lugging it around everywhere. I just use it at home and it's been excellent. The only negative is the nylon handle used to tilt the bevel. It only lasts so long and then the nylon handle slips. I just use a ring spanner. I'll weld it on one day.
PostPosted: Thu Feb 01, 2018 3:33 pm
Thanks for all the advice guys. I've watched numerous video reviews and been reading reviews where ever I could find them and decided to order an Evolution Rage this morning. I've gone for the new R210SMS
http://www.evolutionpowertools.com/uk/build/mitresaws/r210sms/
For the things I want to do and can envisage myself doing in the future it seems like a good fit. I ordered the Evolution 800B stand for it as well.
I'll come back with some feedback when my projects are complete.
PostPosted: Thu Feb 01, 2018 5:13 pm
I had a look at that stand ... too much flex in the arms for my liking. the titan I linked to is much more solid.
