It is currently Sat Feb 16, 2019 8:13 am
PostPosted: Sun Jan 21, 2018 1:33 pm
Been thanked: 1 times
Hi all,
I have a wooden floor downstairs and one of the knots has broken leaving us with a cavity. See the attached picture. Any ideas as to the best way to fix this? At the moment I'm thinking of a resin or wax but wondered if you had any experience with this?
MM
File comment: Hole in wooden floor
PostPosted: Sun Jan 21, 2018 6:38 pm
Has thanked: 103 times
Been thanked: 253 times
Depends a lot on your skill or how you want it to look and for that matter how big the hole is. Simplest method is to replace the whole or part of the board. Another idea is two pack filler which can be coloured by mixing with stain and then further enhancing a grain pattern by "painting" fine lines with a darker stain using a artists brush. That does take a bit of work to get it to look right but can be invisible if done properly. It may not be suitable for areas that see heavy traffic however. Another method is to splice a piece of timber in. Cutting a splice at an angle to the grain will emphasise grain and blend it into the floor better. One of the hardest problems could very well be finding a matching timber for the splice.
PostPosted: Sun Jan 21, 2018 6:46 pm
Has thanked: 1205 times
Been thanked: 1095 times
I've cut a randomly "amoeba" shaped piece of wood from the same lot of timber, and let it in before now. Similar technique to veneer patching. Fiddly though, and you need scribing gouges to do it really.
I've done what Grendel suggests on occasion as well. Two pack mixed with stain and painting darker stain "grain". Works well.
PostPosted: Sun Jan 21, 2018 7:49 pm
Has thanked: 45 times
Been thanked: 729 times
Looks a bit big for a wax fill, hard to tell the scale. If it's as big as I think it is then I would be going for a tinted resin fill.
PostPosted: Mon Jan 22, 2018 8:57 am
Thanks for the replies all, really appreciate it.
It's about 1.5" diameter, roughly speaking, so definitely noticeable. I'll have a look into the things you all mentioned but hoping for a quick fix/minimal effort repair job ideally (call me lazy if you like lol)
PostPosted: Tue Jan 23, 2018 8:26 am
Probably the " minimal fix" would be a combination of filler and splice. Cut a piece of matching timber and bed it into place with two pack . Try to ensure the surface of the splice is flush with the surrounding board and certainly not proud as that would then require planing or sanding down which could encroach onto the already finished surfaces. Any excess filler can be carefully scraped without touching the surrounding area and the whole thing given a coat of ( probably coloured ) wax.
PostPosted: Tue Jan 23, 2018 10:22 am
Has thanked: 700 times
Been thanked: 2026 times
is this floor floating or fixed :dunno:
cron
