It is currently Thu Sep 20, 2018 1:46 am
PostPosted: Fri Jan 05, 2018 4:02 pm
Recently moved into a new house and the previous owner had constructed ceiling storage. I like the idea of providing storage up and out of the way but would like to remake as currently each "U" is screwed into the joist with just 2 screws and it's all a bit rickety. From what I understand screws are not designed to be strong in shear force. So what's best:
    Nails
    Coach screws
    Bolts (not sure if I want to drill through the joist)
    Screws
    Some kind of joist hanger
I looking to store a 3 section ladder and some timber - 50kg weight at a guess?
Or if this is a terrible idea please let me know! :)
Thanks!
Mods - Not really sure if I should put this here or in joinery forum - feel free to move
PostPosted: Fri Jan 05, 2018 4:19 pm
Has thanked: 400 times
Been thanked: 1445 times
Bolting through is the best/strongest option, especially as that timber looks quite dry. If the timber was newer (and consequently wetter) then I'd use Timbalocks or something similar.
https://www.screwfix.com/c/screws-nails ... ertype=hex
PostPosted: Fri Jan 05, 2018 4:39 pm
Has thanked: 2 times
Been thanked: 131 times
mods, whats goin on. my post disappeared an wont cpme back when i edited it?
PostPosted: Fri Jan 05, 2018 4:46 pm
UHM Super Moderator
Has thanked: 178 times
Been thanked: 612 times
Chances are you posted just as the mods were moving it from building to carpentry. Happens occassionally.
For this message the author moderator2 has received gratitude : moderator7
PostPosted: Fri Jan 05, 2018 5:12 pm
https://www.screwfix.com/c/screws-nails-fixings/timber-screws/cat7020001?headtype=flange&screwdrivertype=hex
Hi Ayjay,
Thanks for your post - yes your right timber is dry - its 25 years old. Ok so perhaps my concerns about boring a hole through the joist and reducing strength are not really an issue then? M8/m10 bolt through each one then?
Thanks!
Mat
PostPosted: Fri Jan 05, 2018 10:01 pm
Hi Ayjay,
Thanks!
Mat
Yes, just drill through for a bolt, 8mm will be enough for the weight your proposing. Timbalocks would still work but are more likely to split dry timber unless they're properly pilot drilled (one size for the shank and another for the threaded section).
