It is currently Wed Apr 24, 2019 5:29 pm
 Post subject: LED strip powering
PostPosted: Sun Dec 31, 2017 8:59 pm
Has thanked: 10 times
Been thanked: 1 times
I've got the lay about 15m of RGBW LED strips that are controlled using a Fibaro RGBW controller.
I want these to be able to do a 'hard turn off' at the light switch, so the question is how exactly do the LED strips go about being wired in, assuming I can't just use 1 transformer to power the whole 15m.
Do I have to put transformers every X meters to 'boost' the led strip?
Sent from my Pixel 2 XL using Tapatalk
 Post subject: Re: LED strip powering
PostPosted: Sun Dec 31, 2017 11:10 pm
Has thanked: 709 times
Been thanked: 2041 times
they tend to be a 6amp 12v for every 5m assuming 50/50
PostPosted: Sun Dec 31, 2017 11:18 pm
Has thanked: 41 times
Been thanked: 1470 times
If you want to "hard turn off" via a light switch the the driver / power supply will need to be connected to the light switch. (Where the existing light is)
Some things to note:
You will need to have a driver / power supply "bigger" than your RGB strip will need. So for example if your RGB strip uses 15Watts / metre* you will need a power supply that can supply (15watts x 15metres) 225 watts MINIMUM so one that is 250 watts is fine.
You will need to check with the supplier of the RGB tape how much it actually requires, guess, get it wrong = waste of money.
The power supply / driver must be the same voltage as the LED strip (Probably 12v, but may be 5v)
Because you are using a RGB controller you can not easily "add" power further down the strip (If you were to try, you could not control the colours as you would be by-passing the RGB controller) So I would suggest you ask where you are buying the controller from how many metres can that controller control?
(There is a problem to do with voltage drop, you may have too much RGB tape, hence ask the RGB tape supplier how many metres you can have. It would be great if you posted their reply here :thumbleft: )
Just wondering. If you do as you ask, and turn the supply to the RGB controller off, will you have to re learn it? (I really don't know)
For this message the author someone-else has received gratitude : Evostance
PostPosted: Sun Dec 31, 2017 11:45 pm
Thanks. Interestingly, I just found a diagram on how to wire them correctly:
It would seem for these LEDs, the maximum length is 6m. Rather than power boost them every 6m, you have send the power through the controller like you mentioned, but split it after the controller
PostPosted: Mon Jan 01, 2018 1:03 am
You will still need a power supply that is bigger than the total of your 15m LED strip. It would also be a good idea to check if your controller can carry the amount of current required. The reason I mention it, is I have a controller sitting next to me now and it can only carry 6A, where as the ones I normally have can carry 15A
This one can only carry 6A (And is operated by a hand held remote control)
This one can carry 15A (And is operated by DMX)
As a matter of interest, I would opt to connect your strip the way its done in the 2nd drawing. As you will have 15m of strip I would also suggest you connect it as 3 strips of 5m (if you can) That way you will get an even colour distribution. (The LED strip itself has resistance) The longer it is the higher the resistance, which is why they say a max run of 6m, any longer and the further from the supply the more red the LEDs will be (Red LEDS need less current than any other colour)
PostPosted: Mon Jan 01, 2018 3:51 pm
Ah that's a good point. I've emailed a few LED supplier's who should be able to advise and give me a suitable domestic installation rather than DIY eBay jobs!
PostPosted: Mon Jan 01, 2018 6:14 pm
Nothing wrong with ebay, where do you suppose most (if not all) UK suppliers get theirs from? (same maker as those who sell on ebay do)
Like I said, wire it as the 2nd drawing, use the controller you linked to and a bigger power supply than you need, jobs a good un. (as they say)
PostPosted: Mon Jan 01, 2018 9:19 pm
Only reason I say about eBay is that i've have 8x 5m strips from there, some RGB some RGBW and some white. The white colour reproduction is terrible on some of them - its a greeny colour, others have died and the ones I have now keep flickering randomly
