It is currently Tue Apr 23, 2019 1:39 am
PostPosted: Fri Dec 29, 2017 1:14 pm
It's kind of hard to explain. It just makes a click sound. And it doesn't happen all the time. It's happening more frequently however. Could you guys please be kind enough to watch the 2 short videos and maybe help me out?
https://photos.app.goo.gl/ZvoxA8esKUVT3Rb92
New to forum sorry. Don't know if links are allowed. Will remove post if not.
Please let me know. Thanks.
PostPosted: Fri Dec 29, 2017 1:54 pm
Has thanked: 1001 times
Been thanked: 1897 times
Sounds like a dodgy starter motor. Might be also be a dud battery.
PostPosted: Fri Dec 29, 2017 1:57 pm
Has thanked: 65 times
Been thanked: 676 times
get the alternator and battery tested for a start - check the wiring from the battery to the starter/solenoid
depending on the age and mileage I would say its the starter motor dying - replace it with a good quality item not a cheap Chinese reman junk - if you can afford it go with a oem Toyota item (or a used one)
PostPosted: Fri Dec 29, 2017 2:22 pm
Thanks for the quick response guys.
I'm sorry I forgot to mention but I just had the battery replaced just a couple of days ago. The mechanic said that that might be the problem. Its a brand new battery. But the problem still persists. Wiring from the starter to the battery could be the issue? If not, then I'll have to change the starter motor? Worst case scenario, how much am I looking to spend?
And btw, although it's a 2010 model, it's only got 17,000 miles on it. Don't know if that info is any help. But here it is.
Thanks again.
PostPosted: Fri Dec 29, 2017 4:40 pm
low miles may mean its done a lot of short journeys to the shops and back
As for price - not a clue on the part, but £40-70 to fit it depending where you are
edit.
reman unit £100 for a Chinese one, £130 for Lucas (+£60 core surcharge - refunded on return of the old one),
A new starter - £150 for a Denso, £170 for Lucas or £200 for a Bosch
These are ball park prices
PostPosted: Tue Feb 20, 2018 3:44 pm
sounds a bit similar to my problems with my Toyota Yaris
