It is currently Sat Jan 19, 2019 8:56 pm
PostPosted: Wed Dec 27, 2017 12:57 pm
Has thanked: 65 times
Been thanked: 546 times
It seems easy until you place items in your house. So tumble drier, put an energy meter on the plug and you can measure the electric used. I can also use the washer/drier and also measure electric used. however with the tumble drier I am pumping air heated by the central heating out side as well.
This is just an example, there are many more where some part can't be easy measured. Be it a tungsten lamp which is heating as well as lighting. Or even the size of a dish washer when you use a tablet be it 10 or 20 placinģ.
PostPosted: Wed Dec 27, 2017 1:08 pm
Has thanked: 698 times
Been thanked: 2014 times
with my old 1600 spin speed washing machine and moisture sensor tumble dryer
i worked out a cold fill 1hr cycle and full tumble dry cost about 30p total at around 12p a kwh so stopped worrying as micromanaging the situation would at best save perhaps 2p a wash or 1-£2 a year maximum so not worth any effort :lol:
PostPosted: Wed Dec 27, 2017 2:53 pm
Has thanked: 45 times
Been thanked: 721 times
Make a heat exchanger for the tumble drier and you can recover a large amount of the heat in the winter. Though to be honest for the effort involved it likely isn't worth it.
PostPosted: Wed Dec 27, 2017 3:19 pm
i recon total amount used to to dry a load about 1.25-1.5kw or 15-18p at 12p kwh
if you can recover say 20% thats 3-4p per load at 2 loads a week thats about £3-3.50p a year :dunno:
PostPosted: Wed Dec 27, 2017 3:53 pm
Made from salvaged/recycled materials you can build one in a couple of hours for just a few £'s in parts, whether that is worth it is another matter as you say big-all. Myself I probably would, not so much for the money savings but for the bonus of "free" heat and the fact I think it would be an interesting and useful project. Then again I also would like to build a heat exchange air vent if I am able to in a future house, partly because it would be useful, partly because it would be an interesting project.
PostPosted: Wed Dec 27, 2017 4:02 pm
i think the trouble is the airflow rate and relatively high temperatures mean a big bulky heat exchanger
then because you dont want to waste energy half the time you could use the heat recovered you dont use the tumble but hang the washing out
then then for 25% off the year you dont need the heat as its summer time :lol:
you also need to remember any fins or bends to control the airflow and recover heat may both clog up and overly restrict the airflow causing the machine to operate above temperature cutting out on the safety cutout rather than the normal thermal cutout :dunno:
PostPosted: Wed Dec 27, 2017 5:12 pm
Has thanked: 349 times
Been thanked: 1811 times
Is there a reason (point) to the exercise?
Any energy you can't recover is wasted energy and as daft as leaving the front door and all the windows wide open in winter. In theory you could calculate the u-value for all the walls, roof and floors and calculate the potential heat loss through them but given a lot of the heat comes for the occupants anyway are you prepared to measure the calorific input/output to take these into account for an overall figure?
As a mental exercise it may prove interesting to discuss the various methods required to achieve this measurement but it is a totally impractical actual task.
As ever, make savings in those areas where the largest power transfers occur and concentrate less on the lower powered systems. The energy loss attending to some 'power saving schemes' is probably greater than the value of any financial saving you can make.
Aim to have better 'personal' insulation - decent clothing.
PostPosted: Thu Dec 28, 2017 4:35 pm
I think the idea of heat recovery with tumble drier air or a hob extractor has a problem with fluff or fat build up, however in general the idea of the heat recovery system is good.
As to how much heat is recovered is another thing, I have been supprised how much energy is used by devices which are not switched on, in the main older stuff pre-switch mode power supplies. However it is only a problem in the summer, in the winter all energy ends up as heat anyway.
However in the summer it's not so much wasted energy as over heating the house. But unless one knows how much heat is lost of gained you can't work out which items need extra control.
In a caravan I found a fan behind the fridge blowing the warm air outside really made a diffrence, the caravan stayed a lot cooler.
Tried using a remote switch to switch the TV and all connected items off, it was a failure, the recorder would clearly not record but times and dates also had to be reset and so it simply did not work. The same applies to many more items, either a date or time needs setting, or a button needs pressing for it to work, I had same problem with a battery charger why it is designed so you need to press a button I don't know, but that's how they are designed.
PostPosted: Thu Dec 28, 2017 5:12 pm
This is what happens when you have a Government in thrall to green energy - you find yourself counting the most insignificant energy costs in order to cope when, under ordinary circumstances, they could be passed off as 'inevitabilities' ....
