It is currently Tue Jun 19, 2018 1:54 am
PostPosted: Mon Dec 18, 2017 1:08 pm
Has thanked: 2 times
I have attached a picture of the wiring in my ceiling rose. I just wanted to understand the reasoning behind 1 neutral wire having blue tape wrapped around it aswell as a brown wire with blue tape wrapped around it. It seems to me that there is no reason for this to be there but would appreciate understanding of why this might be.
Also,the switch live wire shown with a brown sleeve is coming from a grey cable, is this anything to be concerned about or treat it just the same as if it was a neutral / blue wire?
I am intending to switch over to an ikea celing light with the L/ N connector block (picture attached) that they have provided. I presume the 2 blue neutral wires feed into the N block and the switch live feeds into the L block and the remaining brown and earth wires can be housed in a suitable connector block?
Many thanks!
PostPosted: Mon Dec 18, 2017 1:10 pm
I have taken the earth cables out purely for a better picture and connected them again before turning on power.
PostPosted: Mon Dec 18, 2017 6:19 pm
Has thanked: 1443 times
Been thanked: 3686 times
Looks like someone has got confunded about sleeving to me. You are OK wiring the new fitting or not ??
For this message the author wine~o has received gratitude : doigy99
PostPosted: Mon Dec 18, 2017 6:39 pm
Approved Electrician
Has thanked: 162 times
Been thanked: 562 times
What's that?
The thing with the pink arrow aiming at it?
For this message the author OnlyMe has received gratitude : doigy99
PostPosted: Mon Dec 18, 2017 8:00 pm
The pink arrow is pointing to the switch live. It has a brown sleeve over it so I could tell but the actual wire is grey rather than the usual blue / neutral. Is it normal to have a grey wire as switch live?
I presume then that the blue tape wrapped around the blue and brown wire does not mean anything that I should be concerned with.
PostPosted: Mon Dec 18, 2017 8:46 pm
Has thanked: 200 times
Been thanked: 122 times
Lighting circuits are the most common to have totally random cables and colours.
I worked on a two way lighting circuit recently where every cable (singles were used) was red. Took a bit of time to work out.
Only the person who wired it knows why and how.
PostPosted: Mon Dec 18, 2017 9:14 pm
Has thanked: 42 times
Been thanked: 1265 times
You can say that again.
PostPosted: Mon Dec 18, 2017 9:15 pm
doigy99, to be honest you would be better off using wago connectors and then a flex to your new light
PostPosted: Tue Dec 19, 2017 3:53 pm
Thanks for all your advice. I did connect live and earths to wago connectors and the remaining neutrals and switch live into the ikea connection. All is working now.
