It is currently Wed Apr 24, 2019 5:35 pm
 Post subject: No central heating
PostPosted: Sat Dec 09, 2017 12:31 pm
Has thanked: 2 times
Hi I'm helping my brother in law to try and sort his central heating.
He has a back boiler behind his fire which you can hear fire up when the heating is called for - but no rads heat up.
I've tried bleeding the system which I then noticed a couple of issues - bleed valve broken on one rad and one rad only bled in drops despite being open for ages.
I then tried to turn off all the rads except one hoping it would heat up but again no luck. I did note however 4 rads had trvs and lock shields that had rusted and just wouldn't move dispute being given a big of persuasion....
I've also seen a pump in the airing cupboard smc gold gp63 I've listened to it to when the heating is called for and it makes no noise at all. I've even put a screwdriver to it to and to my ear but not even a small vibration.
This leads me to think the pump will need replacing. Along with the trvs and a new radiator...
He also has said it stopped heating his water a while ago. Which I think points to the pump or possibly a faulty actuator or mpv.
In his loft he has a head tank-overflow full of murky brown hot water.
Sorry for the essay but any help or pointers would be appreciated
Thanks a lot
Sent from my SM-G935F using Tapatalk
 Post subject: Re: No central heating
PostPosted: Sun Dec 10, 2017 7:03 pm
Has thanked: 1550 times
Been thanked: 3894 times
try turning the pump up to the highest setting, any change ?
For this message the author wine~o has received gratitude : squidman
PostPosted: Sat Dec 16, 2017 11:21 am
Tried it wine o. Not a peep from the pump on any setting despite heating being called for. I'm assuming the pump is dead.
PostPosted: Sat Dec 16, 2017 11:24 am
Has thanked: 840 times
Been thanked: 941 times
You need to check if there is actually 240v at the pump.
If so you could put a towel under the pump, undo the center screw (water will run out) and try turning manually, possibly with a flat bladed screwdriver.
If all above fails, new pump time.
Dave
www.drlgas.co.uk
For this message the author gas4you has received gratitude : squidman
PostPosted: Sat Dec 16, 2017 11:34 am
Great idea. I'll give that a go. I did think it may have tripped a fuse but could see anything.
PostPosted: Sat Dec 16, 2017 12:22 pm
Has thanked: 41 times
Been thanked: 1470 times
I would still check for voltage at the pump first
