It is currently Mon Mar 25, 2019 8:04 am
PostPosted: Fri Dec 08, 2017 1:18 am
Has thanked: 6 times
Hi, guys question I have if I was to install 3 touch control switches to control my 2 lights which switches would I need eg 1 gang 3 way or 1gang 4 way please advise. Thanks in advance.
Sent from my ONEPLUS A3003 using Tapatalk
PostPosted: Fri Dec 08, 2017 5:35 am
Has thanked: 41 times
Been thanked: 1448 times
Depends what you want and what the switches can do.
I shall explain.
"Gang" refers to the number of "buttons" a switch has
So the one above is a 1 gang switch
And the one above is a 2 gang switch
and so it goes on.
"Way" means "the number of switches that control the same light" (Easiest way of explaining it)
So if you have just one switch controlling one light it will be a 1 gang 1 way switch
But if you had 2 switches controlling the same light(s) each switch would be 1 gang 2 way
(If you added more switches to control the same light they would be called intermediate, no matter how many you had)
That is how conventional on / off switches work / called. Electronic switches depend on what the maker of that switch decides. Most stick to the "number of ways" but some use the master / slave method, so as the name suggests you have one master switch and as many as you like slave switches all controlling the same light.
So you have to look at your desired switch maker and see what they offer, as it depends what they call theirs, and how you want to switch your lights, as to what you should buy.
As an aside, it makes no difference to the "name" if a switch operates one light, or ? lights, so long as they all come on at the same time.
For this message the author someone-else has received gratitude : Jimmyjamjar
PostPosted: Fri Dec 08, 2017 1:31 pm
Has thanked: 65 times
Been thanked: 667 times
Do you want all switches to control both lights together - 1 gang 2 way, 1 Gang intermediate and a 1 gang 2 way
or
Do you want 2 switches to control the 2 lights independently - 2 gang 2 way, 2 gang intermediate and a 2 gang 2 way
tbh it all depends on the setup you all ready have in place and the application eg. a hall way over 3 floors (town house type setup)
Do not buy cheap Chinese tat off eBay, Buy Cheap, Buy Twice
Make sure there the 'no common' type
If your not sure what you are doing consult a qualified electrician
For this message the author Bob225 has received gratitude : Jimmyjamjar
PostPosted: Sat Dec 09, 2017 12:27 am
or
:scratch:
PostPosted: Sat Dec 09, 2017 11:28 am
Its hardly rock surgery
1st one is a single circuit 3 way switched
2nd one is a dual circuit 3 way switched
The OP has already posted another thread on this subject
PostPosted: Sat Dec 09, 2017 11:40 am
Has thanked: 107 times
Been thanked: 307 times
I kinda thought the Op had like a hall and landing light and wanted 3 switch positioned to control them, say 1 at door one at bottom of stairs and one on landing, now I am confused by the above replies!!
For this message the author aeromech3 has received gratitude : Jimmyjamjar
PostPosted: Sat Dec 09, 2017 12:19 pm
yes, so did i, its a standard circuit - i should of said 3 location switching rather than 3 way
2 way switching
2 gang 2 way ---- 1 gang 2 way (traditional hall way)
or
2 gang 2 way ----- 2 gang 2 way (you can control all circuits from both locations)
3 way switching
2 gang 2 way ---- 2 gang intermediate ---- 1 gang 2 way (traditional hall way)
or
2 gang 2 way ----- 2 gang intermediate ---- 2 gang 2 way (you can control all circuits from all locations)
The op does state the application it could be a 30 foot lounge, it could be 1 circuit 2 lights and 3 switches, existing circuit or new
PostPosted: Mon Dec 11, 2017 12:27 am
or
The 1st.
And thanks
PostPosted: Mon Dec 11, 2017 12:28 am
And that's correct cheers
PostPosted: Mon Dec 11, 2017 12:29 am
I shall explain.
and so it goes on.
PostPosted: Mon Dec 11, 2017 6:27 am
Has thanked: 1535 times
Been thanked: 3869 times
wiring is like this
For this message the author wine~o has received gratitude : Jimmyjamjar
