It is currently Wed Feb 20, 2019 1:16 am
PostPosted: Fri Nov 10, 2017 12:20 am
Has thanked: 12 times
Been thanked: 1 times
I put plastic sheets over the windows and try to control the humidity but eventually condensation builds up on my single pane windows and the frames get mouldy. I want a sealant that will keep the mould off the wood as much as possible and is easy to remove when it needs to be replaced every couple of years.
Specifically I want to seal where the glass panes meet the wooden frame. I know there are frame sealants but I think they're meant to seal where the frame meets the wall. I used a frame sealant last time and it's a lot of work to remove it as I have 24 panes.
There's glazing silicone like EverBuild 225 but as it's silicone it should be harder to apply and remove than an acrylic sealant.
I'm thinking of using some kind of acrylic sealant with strong anti-mould properties. Any recommendations?
PostPosted: Fri Nov 10, 2017 9:26 am
Has thanked: 5 times
Been thanked: 15 times
You can get glazing putty in a gun tube. It's not actually putty but it is an acrylic exterior /interior window sealant that is paintable. Can't remember brand I used but bought it off the shelf in a glaziers a couple of years ago on the advice of the glazier himself and it was great to use because it goes on like Caulk.
It wasn't anti fungal but paint sticks to it properly unlike silicone, so water doesn't get behind it so quickly.
And it's always advisable to remove water if possible (I keep a chamois cloth around now) but sounds like you have too much glass for that.
Sent from my D5803 using Tapatalk
PostPosted: Fri Nov 10, 2017 9:29 am
http://www.geocel.co.uk/catalogue/singl ... zing-putty
I think it was this.
For this message the author Barry_Convex has received gratitude : dorsetbee
PostPosted: Fri Nov 10, 2017 10:39 am
Has thanked: 45 times
Been thanked: 731 times
A window vac is great for removing condensation quickly and with no mess, you might like to try that.
For this message the author Rorschach has received gratitude : dorsetbee
PostPosted: Tue Nov 14, 2017 10:15 pm
Thanks for the tips!
