It is currently Wed Feb 20, 2019 1:17 am
 Post subject: Help Identify Valve
PostPosted: Mon Nov 06, 2017 10:16 am
Has thanked: 1 times
Been thanked: 3 times
Hi, I have two valves (On the central heating feed + return) which are leaking through the cut off control. I need help identifying what type they are(pressure\bleed or something else) and what I might be able to replace them with without having to change too much piping around (IE call a plumber).
For this message the author jeff2001 has received gratitude : multiman
 Post subject: Re: Help Identify Valve
PostPosted: Mon Nov 06, 2017 11:12 am
Has thanked: 840 times
Been thanked: 940 times
No need to change any pipe work, just buy a new valve.
The front bit looks like a drain off.
What boiler is it?
Dave
www.drlgas.co.uk
PostPosted: Mon Nov 06, 2017 11:33 am
Thanks, its a Valiant EcoTec (Cant remember model number off hand but on a guess its the 835)
PostPosted: Mon Nov 06, 2017 11:44 am
Has thanked: 643 times
Been thanked: 1815 times
This is it I think https://www.heatingspares247.com/vailla ... 14731.html Shop around though, that is too much in my opinion.
Painting with BIN
For this message the author dewaltdisney has received gratitude : jeff2001
PostPosted: Mon Nov 06, 2017 11:48 am
dewaltdisney wrote:
This is it I think https://www.heatingspares247.com/vaillant-central-heating-service-valve-014731.html Shop around though, that is too much in my opinion.
Thanks so much, definitely looks correct.
PostPosted: Mon Nov 06, 2017 1:19 pm
That’s an ecomax valve.
Not a bad price really dwd especially if delivery is included.
Sadly one gets ripped off for isolating valves, hence why I use them as a last resort, as a lot will leak after closing them.
Dave
www.drlgas.co.uk
PostPosted: Mon Nov 06, 2017 1:41 pm
Blimey Dave, I thought it was a bit strong but hopefully the OP might find a local supplier a bit cheaper. I guess the replacement of this valve is going to be a full drain down?
Painting with BIN
PostPosted: Mon Nov 06, 2017 2:00 pm
That's exactly what happened, I closed them to do a full drain down when replacing a few radiators.
The sad thing is that are both leaking, the plus side is that although they are pricey it looks like an easy swap job.
Thanks again to both of you for your help :thumbright:
PostPosted: Mon Nov 06, 2017 4:53 pm
Has thanked: 696 times
Been thanked: 28 times
Yes you will need drain down system and 2 nuts to release valve make sure you get new washers with valves.
