It is currently Thu Jan 17, 2019 3:02 am
 Post subject: My first router table
PostPosted: Fri Nov 03, 2017 2:05 pm
Has thanked: 45 times
Been thanked: 718 times
Built my first little router table, just something basic to make using my new Katsu router a bit safer and more convenient with dust extraction. Made entirely from scraps I just wanted something small and easy to store that could be setup in a workmate. MFC for the table top and some framing lumber for the fence which I trued up with a jack plane so it is straight and square to the table. Could do with putting some melamine or something on the face so it slides a bit easier, I may re-visit the fence in the future. Happy with the table top though. And happy with the single pivot principle of the fence.
Works a treat, nice and stable and feels very safe. Dust extraction is superb, nothing seemed to escape once the cutter was in the workpiece, the auto socket on my parkside vac makes it super simple to use and I don't have to reach under to switch the router on and off.
For this message the author Rorschach has received thanks - 2: Job and Knock, multiman
PostPosted: Fri Nov 03, 2017 4:21 pm
Old School Chippie
Has thanked: 766 times
Been thanked: 1535 times
Nice one! :thumbright:
Thanks for sharing
It's the sort of thing I've made up on job sites a few times over the years (albeit a bit neater in the execution!), the main differences being that my fence would generally either be a straight rip of 18 to 25mm ply or a bit of 3 x 2 PSE softwood and that mine sit on top of two trestles or sometimes a box. BTW a quick rub with the nub of a wax candle on the bed and face of the fence can work wonders in terms of "slideability". Works on the soles of hand planes and bottoms of routers and power planers, too
How'r you finding the Katsu? I notice that they've recently added an offset base to the range of accessories but at under half the price of the OEM version. The Katsu bases fit the RT0700 as well. Bit of a niche market item but nevertheless good to see they've done it.
The plastic sub-base on that offset base together with a handle makes a good extended base for extra stability, something AIM Tools must know as they offer a complete unit now
PostPosted: Fri Nov 03, 2017 7:12 pm
This is far from neat as it is only made from scraps I had laying around but the important things are there, the router is square to the table and the fence is also square to the table and locks securely in place.
I am really quite pleased with the Katsu, sure it has a few rough areas here and there but the motor is quiet and very smooth, everything works as it should and it seems to have enough power as long as you are conservative with your cuts. Dust extraction using the trimmer base is superb, even better when using it on my little table. For the price I think it's a stonking bargain.
I did see those offset bases, not something I think I will use but good to have such an accessory available.
I think the first thing I will use this table and router to build is a base that will slide along my track saw tracks as I reckon that would be really good for doing dados.
PostPosted: Sat Nov 04, 2017 9:27 am
Old School Chippie
If it's any hep Makita already do a guide rail adapter which fits and might be the right thing for housings providing your cutter matches the timber thickness:
One of the good features of the RT0700/Katsu is that the fence rod diameter (8mm), spacings, etc are identical to those on the Makita RP1110C, deWalt DW615/621/622, Elu MOF96/OF97, Trend T5, etc. so there are many options open to you for expansion in that direction
PostPosted: Sat Nov 04, 2017 10:40 am
That's good to know. I was thinking of just making my own since I am pretty sure I have rods of the right size and I I would just make my own little guide block from wood. Something to research anyway.
From what you say about accessories I think getting the Katsu and selling the Bosch was a good plan.
PostPosted: Mon Nov 06, 2017 1:17 pm
Looked through my collection and I found I have a couple of feet of 5/16th Chromed rod which will do very nicely for making up a guide rail adaptor I think.
PostPosted: Mon Nov 06, 2017 1:49 pm
Has thanked: 626 times
Been thanked: 1794 times
I made my first router table around my Blacker and Decker drill stand as my first B&D router (1979) was more like a drill fitting. Mounted overhead I used a variety of guide pins and fences to do what I wanted. Necessity is the mother of invention and looking back I managed quite a lot. My purpose made router table has been great though and I have done loads of different routing work.
I am sure you will move forward to a shop bought table in due course but what you have made will do plenty of jobs to broaden your experience. :thumbright:
Painting with BIN
For this message the author dewaltdisney has received gratitude : multiman
PostPosted: Mon Nov 06, 2017 4:54 pm
Has thanked: 696 times
Been thanked: 28 times
Nice work
PostPosted: Tue Nov 27, 2018 9:47 am
I finally did get around to making that track adaptor for the router, have started a separate thread for it.
PostPosted: Tue Nov 27, 2018 10:00 am
Been thanked: 2013 times
nice job well done
missed this thread the first time round :thumbright:
