It is currently Tue Nov 13, 2018 4:51 pm
PostPosted: Sun Oct 22, 2017 11:47 pm
I have taken the plaster off the wall to expose the bricks. There is now a gap all the way round the ceiling ranging from a few mm to 6 cm with the accumulated dirt and dust of decades dropping through. The wall area varies from a wooden beam to brickwork .
I will be putting up a wooden ceiling under the plasterboard but there will still be gaps between the ceiling wood and the brick walls. I do not want to fill those so how can I block the gap betwen the plasterboard underneath and the brick/ wood as there is nothing for any filler to hold onto ?
PostPosted: Mon Oct 23, 2017 6:39 am
Has thanked: 44 times
Been thanked: 698 times
Can you post pictures, I don't understand exactly what you are saying.
PostPosted: Mon Oct 23, 2017 8:36 am
Sorry but my photos keep getting rejected as too many pixels.
It is simply a gap between wall and the old plasterboard ceiling, after the plaster has been removed from the walls, that varies between 3cm and 8cm that I want to fill to stop dust and rubbish falling through ffrom the roof cavity above onto the ply ceiling I will fit below.
The problem with any filler is that there is nothing for it to grab to being in the ceiling with nothing above.
Basically how do I stop any foam or other filler dropping out ?
PostPosted: Mon Oct 23, 2017 9:23 am
Has thanked: 406 times
Been thanked: 1468 times
Pictures can be resized using one of many programmes, you probably already have *Paint* on your PC.
Expanding Foam is the simplest method: damp the area first with plain water in a small garden sprayer, (or you may have something under the kitchen sink that could be pressed into service ) then squirt foam into the gap, you don't have to fill the gap with foam, it will expand and do that itself.
The foam won't fall out, it sticks at about number nine blanket strength.
When it's cured any excess can be cut off flush with the wall using a sharp knife.
PostPosted: Mon Oct 23, 2017 10:26 am
I have attached a photo . The problem is that there is nothing above the gap and nothing to one side except the void above the plasterboard so nothing except the wall for the foam to attach itself to. So it will then drop down rather than span the gap which is what I want it to do.
PostPosted: Mon Oct 23, 2017 12:08 pm
Has thanked: 213 times
Been thanked: 159 times
Are you plastering the walls or applying plasterboard?
PostPosted: Mon Oct 23, 2017 12:22 pm
Walls are remaining bare brick. I want to fill the gaps as they are and place a plywood ceiling covering the existing plasterboard. That is what makes it a problem I want to block the gaps that exit as I do not want to touch any after the plywood has gone up as the ply will be oil stained to a finish.
If I block them now then nothing can drop through onto the plywood or through the gaps between ply and brick which I am happy to keep.
I have done something similar in a small bathroom but the gaps were smaller.
PostPosted: Mon Oct 23, 2017 12:40 pm
Has thanked: 616 times
Been thanked: 1751 times
Far be it from me wishing to pee on your bonfire but will a stained ply ceiling make the room very dark and oppressive. You must always have an eye to the future where a finish like this would make a property hard to sell, and no one knows when they may have to move on in time. Even traditional timber frame cottages are moving to having the beams stripped and white washed as most people want a light contemporary feel to their homes these days.
I am sure you have your reasons.
Painting with BIN
PostPosted: Mon Oct 23, 2017 1:59 pm
It is a relatively high ceiling, over three metres and will be a light stain on beech ply with brick and light green walls with a huge stripped window. I did a simlar room with a lower ceiling with yellow and mahogany stained ply on walls and yellow ceiling. . The contrasts show the light.(I think)
PostPosted: Mon Oct 23, 2017 4:12 pm
From your description, I wasn't expecting the gap to be horizontal. I don't think foam will stay in there as it is.
(Normally the ceiling is done first and then the walls plastered up underneath, I think your ceiling must have been replaced and the walls left as was at one time).
If I was covering that in timber, I'd batten it out first, a wide batten at the gappy edge will cover the gap, paint it matt black before you board the ceiling and any of the batten that shows - won't.
Alternatively, some strips of p/b or anything really to close up the worst of it and then foam it.
PostPosted: Mon Oct 23, 2017 4:24 pm
Yes I am battening the ply out on the joists as the ceiling is uneven anyway. There is nothing behond it except the roofso I need to keep it
I was hoping to block any dirt getting down from the roof area and and resting in the ply of through any gap.
I think your idea of battening the edges might help if I do that to the plasterboard and then fill any gap with foam.
Just to be sure, if anything gets through I can do rhe same when putting up the ply.
I think you may have solved it.
