It is currently Mon Jan 21, 2019 5:40 am
PostPosted: Fri Oct 20, 2017 5:29 pm
Has thanked: 2 times
Been thanked: 1 times
Hi there,
I've been having an issue with my bathroom extractor fan - quite sure I know what the issue is but thought I'd check with you good folks before electrocuting myself!
To sum up:
* Fan always runs, whether lights are on or off
* Definitely a switched fan - there's a live and a switched live input for wiring, both are connected
* There's a LED power light on fan. It goes off after a while when the lights are off, but fan continues to operate. When i switch lights on, the LED turns back on
My guess here is that the live and the switched live are swapped. Would that make sense and result in above behavior?
Happy to take photos as required!
PostPosted: Fri Oct 20, 2017 5:33 pm
Has thanked: 39 times
Been thanked: 1413 times
More information is required.
Has the fan recently been changed?
Has any wiring recently been changed?
Is this a brand new installation?
Anything else you would like to tell us?
PostPosted: Fri Oct 20, 2017 5:35 pm
Moved into this place 6 months ago. Fan doesn't look new. No idea of history re: changed wiring.
Identical fan in another bathroom works as intended - stays on for 5-10 mins after you switch off lights, then turns off. This one just remains on.
PostPosted: Fri Oct 20, 2017 5:36 pm
Has thanked: 1509 times
Been thanked: 3834 times
I'd hazard a guess that you are correct. Lecky off and swap live/permanent live.
If that doesn't work then the timing circuit has probably failed... not normally a replaceable part so time for a replacement fan.
(could also be a humidity stat failure, but you don't mention a humidistat)
PostPosted: Fri Oct 20, 2017 5:38 pm
what's worst that could happen if i swap permi live + switched live? Fan just wouldn't turn on right?
PostPosted: Fri Oct 20, 2017 5:42 pm
I am thinking the timer has given up, but swapping Live and switched live will do no harm.
For this message the author someone-else has received gratitude : chamsters
PostPosted: Fri Oct 20, 2017 6:40 pm
exactly. or the fan would still constantly run as it already does.
For this message the author wine~o has received gratitude : multiman
PostPosted: Fri Oct 20, 2017 7:04 pm
Approved Electrician
Has thanked: 168 times
Been thanked: 582 times
Doing that should make the fan act a non timed fan ie it will only switch on with the lights (works with 99% of timed fans).
So unless the wiring to the fan is incorrect, that should prove that the timer is faulty.
For this message the author OnlyMe has received thanks - 2: multiman, wine~o
PostPosted: Fri Oct 20, 2017 7:10 pm
Very possible. Or an incorrectly set stat.
For this message the author OnlyMe has received gratitude : multiman
PostPosted: Sat Oct 21, 2017 9:00 am
Has thanked: 696 times
Been thanked: 28 times
A model may help if you can see a humidistat will have a small sensor on board to sense air levels and have an adjustable screw or knob on it normally with a + - on there.
PostPosted: Sun Oct 22, 2017 10:49 am
Has thanked: 11 times
Been thanked: 56 times
Surely the fan has been running fine up till now, have the wires magically swapped over on their own? I would say it is either a faulty pcb causing the timer fault, or the timer needs turning down, or the fan has a humidistat and that needs turning up.
PostPosted: Sun Oct 22, 2017 10:52 am
Hi folks,
OK so there was no impact turning up the timer. Could not find humidistat. Ended up getting replacement fan on amazon for £15, installed last night and it works great with same wiring set up.
So - was definitely an issue somewhere on the old fan, likely a shot timer.
Thanks for the help!
For this message the author chamsters has received gratitude : multiman
PostPosted: Sun Oct 22, 2017 10:54 am
Great glad all sorted
For this message the author multiman has received gratitude : chamsters
