It is currently Sat Jan 19, 2019 12:39 pm
 Post subject: wall tie
PostPosted: Thu Oct 19, 2017 12:02 am
Hi I have built a 6m long by 3.2m stud wall 50mm off a stone party wall. Any ideas of how to tie the stud wall to the existing stone wall. All wall ties i have seen are for brick and I can't screw or nail from the wall side! Any ideas or suitable tips appreciated
 Post subject: Re: wall tie
PostPosted: Thu Oct 19, 2017 8:11 am
Has thanked: 101 times
Been thanked: 247 times
You can't go far wrong with a length of allthread and a tube of resin . Drill right through , clean out , fill the hole with resin , shove in the allthread and tighten up the nut after it's set. Cheap enough , simple to do and pretty difficult to get wrong.
PostPosted: Thu Oct 19, 2017 5:30 pm
Has thanked: 1509 times
Been thanked: 3834 times
I normally screw through the uprights of the stud into the wall...
PostPosted: Thu Oct 19, 2017 7:33 pm
Yes I'd normally screw but peasoupblu mentioned the stud being 50mm off the wall which would entail longer screws.
However , just rereading this I pictured the studwork at right angles to the stonework but now I think it's more likely to be in line with it . In which case it should be possible to put 50mm packers behind the studs ( presumably with a dpc membrane ) screwed directly to the wall with screws and plugs and a screw skewed through the stud into that packing with perhaps a plastic packer if needed. Althernatively the simplest method would be right angled steel brackets screwed to the wall and into the sides of the studs.
