It is currently Mon Sep 24, 2018 1:15 am
Post new topic Reply to topic  [ 34 posts ]  Go to page 1, 2, 3  Next
 Post subject: Door Bell saga
PostPosted: Mon Oct 16, 2017 1:28 pm
Has thanked: 592 times
Been thanked: 1720 times
We had a battery powered wireless doorbell. The batteries were always running out (weeks) and it was a nuisance as people had to thump on the door which is a bit alarming at times. Also the bloody thing has to go through twenty different sounds before we get to the simple ding dong we want after new batteries were installed.
I had a look at replacements but they were all unsuitable. I did not like the plug in type and mains wired is too difficult to do for a bell where it is. Anyway I bought a simple wired battery ding dong from Screwfix see https://www.screwfix.com/p/byron-wired- ... hite/80766
I go to rig this up and find I have not got a thin drill long enough to go through the 4" door frame. I thought I will never marry up drilling from both sides and the longer drills were far too wide a hole for the frame. I had an idea and took the drill out of a thin morticing chisel and that worked a treat. Then wiring it up I did not want those bloody cable clips everywhere so I got my (recently found again) glue gun and stuck the cable which worked really well and it is not noticeable. All done press the bell.......ding, no bleedin' dong. Grrrrr......... the new square battery I got for £3 must be duff. Check it with my multimeter (not that I know what I am doing) and it showed 9 amps so I must have the setting wrong :lol:
I tried the battery out of the smoke alarm and that was the same. Take the bell down and back to Screwfix and swap it. Rig it all up again and ding.......... FFS. I tell Mrs D that is how it will stay :angryfire: I bought another couple of batteries in Poundland and still the same.
Now to my mind this is a very simple mechanism (is it a solenoid) where a plunger is pulled back and released so it hits one chime plate and then the other before centring again. Can these be adjusted?
It says in the Screwfix listing that a Helpline is available but I cannot find it anywhere.
Any ideas??
Thanks for reading
Painting with BIN
 Post subject: Re: Door Bell saga
PostPosted: Mon Oct 16, 2017 3:22 pm
Has thanked: 52 times
Been thanked: 548 times
9v battery ? not to sound daft but did you wire it correctly and is the solenoid in the correct orientation ? worn out bell push ? not releasing would make it ding but not dong and will a pull a low current enough to kill a battery
Duff batch of bells maybe ? our Friedland (looks like a D422) takes 4 d size and I cant remember when I changed the batteries last,
https://www.amazon.co.uk/Friedland-D422 ... B001T2JG08
Been there, Done that, friend had a wireless bell that use to set the alarm 2 door down when it was rung
For this message the author Bob225 has received gratitude : dewaltdisney
PostPosted: Mon Oct 16, 2017 3:24 pm
Has thanked: 137 times
Been thanked: 151 times
All I can see at the bottom of the home web page is a contact us button which throws up a 24/7 telephone number 03330 122 112 and allegedly it's mobile friendly.
Mike
For this message the author London mike 61 has received gratitude : dewaltdisney
PostPosted: Mon Oct 16, 2017 3:32 pm
Has thanked: 45 times
Been thanked: 1335 times
The bell you linked to has its own transformer, it does not run on a battery. It does say in the blurb "mains operated"
How about a picture of it with the cover removed?
For this message the author someone-else has received gratitude : dewaltdisney
PostPosted: Mon Oct 16, 2017 8:07 pm
SE, I think they are common comments on the Byron range on SF, mine is deffo a battery bell wired to the bell push.
Flash, all components are new and it is very simple wiring to two terminals. I reversed the battery feed contact wires (did I imagine that you put that in your post earlier when I read it?) but it made no difference.
Mike I will give them a ring tomorrow thanks for finding that number I could not see it :oops:
Thanks for the input guys :thumbright:
Painting with BIN
PostPosted: Tue Oct 17, 2017 7:55 am
Has thanked: 64 times
Been thanked: 541 times
With the simple ding dong door bell the ding is done by electric and dong by a spring, if not level often dong will not work, and I have found often the spring need compressing or stretching because it is missing ding or dong.
For this message the author ericmark has received thanks - 2: Dave54, dewaltdisney
PostPosted: Tue Oct 17, 2017 10:00 am
Mike
Just phoned the number and the recorded message says the service is down :lol: :lol:
Painting with BIN
PostPosted: Tue Oct 17, 2017 11:57 am
Mike
Bloody screwfix, you would think a company of that size would be able to keep the system going even if it means using a temporary phone number.
Good luck getting through later on.
Mike
PostPosted: Tue Oct 17, 2017 11:58 am
when the battery do drop down it dings lightly, but you get a donk or a light thud as I cant compress the spring, so I doesn't fire it back
My mistake there C size and not D's
only reason I asked about wiring is some bells have 4 terminals 2 for power (used with a external supply) and 2 for the push and they can be wired in different configs
tbh I don't know why this door bell stuff is in my head :?
PostPosted: Tue Oct 17, 2017 12:34 pm
Has thanked: 1119 times
Been thanked: 1034 times
How far's the cable run DWD? If it's too far the bellwire resistance will come into play and you won't get a vigorous enough ding, to give you the dong. :shock:
See if it works by momentarily shorting the push connections at the bell end with a bit of wire.
PostPosted: Tue Oct 17, 2017 2:30 pm
I did that Dave and it still only manages and the bell to push button is only about a metre. I have traced the manufacturers in Bromsgrove so I will try them direct if I can reach anyone. I suspect it is cheaply made rubbish at £12 but is only a simple unit. I am in the middle of BIN painting at the minute (waiting for it to dry for the second coat) what fun :angryfire:
I will keep you all posted on how the bell saga is going :thumbright:
Painting with BIN
PostPosted: Tue Oct 17, 2017 3:49 pm
Just thinking aloud really mate. I've had a job with them a couple of times. It's the classic problem. Ding but no dong. . .
PostPosted: Tue Oct 17, 2017 6:47 pm
Has thanked: 1484 times
Been thanked: 3785 times
HAAAAA DWD hasn't got a Dong... I'd long suspected as much :hiding: (sorry DWD )
My current doorbell is a siemens jobby that plays MP3 files. (I don't have a "Dong" either) :oops:
At the mo it plays part of the Harry Potter theme... When I have time I'll change it to the "Tardis" dematerialising...
PostPosted: Tue Oct 17, 2017 6:52 pm
PostPosted: Tue Oct 17, 2017 7:06 pm
Mike
I thought the number was tech support? so that will not be screwfix.
