It is currently Mon Mar 25, 2019 8:00 am
 Post subject: hall lights problem
PostPosted: Sun Oct 08, 2017 2:31 pm
Hi all,
Firstly a little background.
I live in a small bungalow so no upstairs wiring to complicate matters.
I recently fitted a new bathroom fitting which went without any problems apart from having to
climb in the loft (no easy feat when one is way past retirement age)
The wife then decided the hall lights needed changing,so thinking it would be piece of cake down came the old ones,(how wrong can one be)
There are 2 lights 1 at each end of the hall serviced by 2 switches both of which turn both lights on and off.
Stupid me did not take note of the existing connections so i now find myself in a predicament as follows.
One of the lights has 10 wires as follows 2 gey cables each with a red a black and an earth
1 tgrey cable with a brown a blue and earth.
a thinner grey cable with just a single red wire.
The second light fitting has the same apart from no single red.
I think the single red has something to do with either the porch light or a smoke alarm also fitted in the hall but not 100% sure.
I have tried the normal procedure of all earths together, all reds together and 2 of the blacks together (should say 1 black and 1 blue
and the other black which i think is the switch live but this does not work. :dunno:
With a mains tester i think i have identified 1 live red and 1 live black at both light fittings but then again i could be wrong.
I also do not think these lights are on a complete loop because if i separate and make safe every 19 in total all the other lights in the property still work as normal.
As previously stated i am an OAP with limited finances and would prefer to be able to fix this myself. If it needs qualified electrician then so be it.
Any advice on how i should proceed would be greatly welcomed and appreciated
 Post subject: Re: hall lights problem
PostPosted: Sun Oct 08, 2017 3:04 pm
Has thanked: 1535 times
Been thanked: 3869 times
:welcomeuhm:
Lights are generally on a radial circuit. It MAY be that in your case the "Loop" is at one of the switches, Pics of the wiring at the switches may help.
PostPosted: Sun Oct 08, 2017 3:31 pm
Not to clever at posting pictures but switches wired as follows.
Both the same red incoming at th top
black and red at the bottom red on right black on left looking straight at the switches.
Hope this is helpful. Ernie.
PostPosted: Sun Oct 08, 2017 3:35 pm
Not looped at the switch then and not wired "conventionally" I can't help any further, perhaps one of our other members can.
PostPosted: Sun Oct 08, 2017 3:40 pm
Thanks for trying to help.Ernie
