It is currently Fri Feb 22, 2019 12:44 am
 Post subject: water base stains
PostPosted: Sun Oct 01, 2017 4:49 pm
We have water stains on wall and celiing.
All dried up but stains does not go after appying matt paint.
Shoud l use Zinseer 123 or Polycell Trade Stain Blocker.
Which one works best?
Thanks for all help.
 Post subject: Re: water base stains
PostPosted: Sun Oct 01, 2017 6:05 pm
Elephant Man
Has thanked: 606 times
Been thanked: 1366 times
I'd be more inclined to go with Zinsser Coverstain or oil undercoat. Coverstain dries far quicker, and is more effective, but undercoat will do at a push. :thumbright:
Nihil expectore in omnibus
PostPosted: Sun Oct 01, 2017 6:50 pm
Has thanked: 244 times
Been thanked: 249 times
123 plus is the better one. I'd always follow Dynamods advice.
For this message the author Desmondo15 has received gratitude : dynamod
PostPosted: Sun Oct 01, 2017 7:29 pm
Elephant Man
Thank you, kind sir :salute:
For this message the author dynamod has received gratitude : OchAye
PostPosted: Mon Oct 02, 2017 12:10 am
Has thanked: 766 times
Been thanked: 858 times
But the advice was to use coverstain not 123 ... whatever.
PostPosted: Mon Oct 02, 2017 8:00 am
The original question was " Should I use Zinsser 123 or Polycell Trade stain blocker"
Using Zinsser 123 would be a mistake for water stains whereas Zinsser 123 plus has more weight to it as a stain block so that was some help for mane.
For personnel reasons I'd have used 123 plus (Asthma) but I advised to go with Dynas advice due to his vast experience.
Hope this helps you Ochaye.
For this message the author Desmondo15 has received gratitude : OchAye
PostPosted: Mon Oct 02, 2017 6:49 pm
Yup :salute:
For this message the author OchAye has received gratitude : Desmondo15
PostPosted: Thu Oct 05, 2017 5:59 pm
I used zinser 123.....
should I do prime before applying dulux matt absolute white emulsion
or should I put prime first?
I have Benjamin Morore primer at home so can try that.
On the wall I have to use Dulux eggshell so not sure how eggshel paint will work on top of Zinser 123?
thanks for all help
PostPosted: Thu Oct 05, 2017 6:10 pm
Has thanked: 1531 times
Been thanked: 3852 times
1-2-3 isn't a stain block. You need something with more body. BIN will work as will Allcoat (Both Zinsser products) or an oilbased undercoat (probably the cheapest option)
PostPosted: Thu Oct 05, 2017 6:16 pm
should I sand down 123 and then apply BIN?
single or double application of BIN?
I heard flashing issue with BIN.
Should I prime after BIN ?
PostPosted: Thu Oct 05, 2017 6:28 pm
Just go over existing with a good stain block no need to sand.
PostPosted: Thu Oct 05, 2017 6:33 pm
I have ZIN spray based so will give a go?
I hope I will not get flashing issues with it.
PostPosted: Thu Oct 05, 2017 6:42 pm
Should be OK if you use a decent trade paint over, may need 2 coats.
PostPosted: Thu Oct 05, 2017 6:44 pm
123 plus is the water stain option and would work fine. Any coating on top, same with BIN which is more heavy duty but very smelly and harder to apply.
They all have their merits, 123 will do tar, it's got the same resin as Allcoat but it's not so good for water stains.
Zinsser also do a solvent based primer and finish that covers a whole list of stuff which is also extremely low odour so there's lots of choice.
There's more than one way.
A oil based undercoat to be fair may yellow.
PostPosted: Thu Oct 05, 2017 6:54 pm
I have BIN at home, it is spray one. Just done one coat.
may do another in 30 mins
should i then apply dulux paint ?
