It is currently Wed Jan 23, 2019 8:11 pm
Post new topic Reply to topic  [ 51 posts ]  Go to page 1, 2, 3, 4  Next
PostPosted: Wed Sep 27, 2017 5:49 pm
Has thanked: 1 times
Been thanked: 1 times
hello
can you advise please i`m running a 4mm or 6mm armored cable to my shed
the length of the run is just over 35M
i`m buying 40A 3-Way Garage Kit with 2 MCBS
This 40A 3 way garage kit
Comes with - 1 x 32A MCB, 1 x 6A MCB. DIN rail, neutral cable, neutral and earth terminals and busbar
MCB - 2x MCBs (1x 6A & 1x 32A)
I want to use a fridge freezer and install a light So one double socket and a light
i enclose a photo of consumer box the water heater fuse is no longer needed
as i have a combi boiler now
can you advise what MCB needed in my consumer box 32amp or higher ?
about the armored cable better to dig a trench 1ft deep
or could i pin it to my wall
thank you for any of your advise Paul
PostPosted: Wed Sep 27, 2017 8:31 pm
Approved Electrician
Has thanked: 168 times
Been thanked: 582 times
35m is quite a distance. Now it's not the load that is the problem (you have very little load) but the fault current at 35m if you do not use the RCD side of your CU to power the shed - 35m and non RCD protection at 6mm would need some calcs doing if you have a TNS supply (not a problem with a PME supply). I'll calculate them later for you.
You have to balance up the pros and cons of how you wish to use the RCD protection.
Ideally the shed should not be RCD protected at the head end and the RCD protection should be provided by your new CU in the shed. However if that RCD trips then how long would it be before you knew and lost the contents of the FF?
On the other hand if you use the RCD in the house to power the shed and a nuisance trip occurs on one of the other circuits RCD fed house circuits then you will also lose the shed power. Not nice if you are on holiday.
If you are happy with a maximum 16A load (ie roughly the same as an extension lead) then move the 16A unused RCD to the non RCD side of the CU and power the shed from that - a 16A supply with 6mm SWA does not require any calcs and is quite safe.
And do fit the 6mm not the 4mm SWA. It will allow for upgrading the power should you need to.
For this message the author OnlyMe has received gratitude : multiman
PostPosted: Wed Sep 27, 2017 11:07 pm
thank you onlyme
for your kind advice
you say to move the 16amp i amuse to the right where the light mcb are ?
i will only ever use a lawn mower and use the fridge and freezer in the shed
thank you paul
PostPosted: Thu Sep 28, 2017 1:04 am
hello onlyme
can you advise me are these items good for what i want to do
to run a fridge freezer and lights in my shed
all from Screwfix
Prysmian LV Armoured 6943X 3-Core Cable 6mm² x 50m Black (36123)
British General 5-Module 3-Way Populated Garage Consumer Unit (1926G)
1 x 40A 30mA RCD
2 x MCBs (1 x 6A & 1 x 32A) ( they also sell with 1x6amp 1x 16 amp ? )
Flexible Busbar
thank you Paul
P.S best to bury in ground 1ft deep or pin to a brick wall ?
PostPosted: Thu Sep 28, 2017 7:28 am
Been thanked: 43 times
Slightly off topic, do be aware that most fridge/freezers stop working below a certain temperature, unless you have a unit which says its ok to use in a shed/garage or you could heat the building , 35mts is a long way to go for a cold beer :wink: Nos
For this message the author Nos has received gratitude : OnlyMe
PostPosted: Thu Sep 28, 2017 8:14 pm
paul777 wrote:
hello onlyme
all from Screwfix
1 x 40A 30mA RCD
Flexible Busbar
thank you Paul
They are the correct items. I would however if you have electrical wholesalers near you call into one and ask how much their SWA is. You could probably knock £70 off that price. Or there is Screwfix item 51385 if you can still get it. That would allow a 32A non RCD supply to the shed without any calcs.
Well buried cable looks a little better than clipped cable, it makes no difference to your electrical requirements.
PostPosted: Thu Sep 28, 2017 8:26 pm
An excellent point sir :salute:
I do believe that all Beko ones do work at cold temperatures.
PostPosted: Thu Sep 28, 2017 8:44 pm
Has thanked: 1509 times
Been thanked: 3840 times
Indeed you need to look at the climate class rating for the appliance
CLIMATE CLASS MINIMUM TEMP MAXIMUM TEMP
N 16 Deg C 32 Deg C
SN 10 Deg C 32 Deg C
ST 18 Deg C 38 Deg C
T 18 Deg C 43 Deg C
PostPosted: Sat Sep 30, 2017 1:39 am
onlyme
just looked in screwfix that number you gave me 51385
that cable has 4 wires not the standard 3 wires live com earth
thanks again paul
PostPosted: Sat Sep 30, 2017 6:43 am
paul777 wrote:
onlyme
thanks again paul
I know it has 4 cores. I was going to suggest that you used 2 of them as an earth. It's a drum of 6mm 4 core SWA that is cheaper than the drum of 6mm SWA 3 core you are looking at and made by the same company.
It's on clearance because screwfix do not sell a lot of it (they are not proper electrical wholesalers)
PostPosted: Tue Oct 03, 2017 12:38 am
thank you onlyme
one last advice thinking of safety
would you recommend
Earth Rod 3/8" 4ft (28044)
at new consumer box by shed ?
thank you paul
PostPosted: Tue Oct 03, 2017 7:23 am
Has thanked: 39 times
Been thanked: 1415 times
paul777 wrote:
would you recommend Earth Rod 3/8" 4ft (28044) at new consumer box by shed ?
Why?
PostPosted: Tue Oct 03, 2017 7:48 pm
There is no need to use an extra earth rod in most circumstances (certainly not in domestic installations). In fact the installation of an extra earth rod can sometime make things worse!
S-E There are times you may wish to fit an earth rod, eg you would need a massive earth cable to export the incoming earth due to extraneous conductive parts in the outbuilding, in which case it might make more sense to not export the earth, use a local earth rod and make the outbuilding a TT supply using the rod as the ONLY earth to the outbuilding and bonding the extraneous parts in the outbuilding to that earth rod.
Paul I would not suggest the use of an earth rod in your case, unless you have a lot of metal in the shed bolted or sunk into the ground. If you have then your install would need to be redesigned.
PostPosted: Tue Oct 03, 2017 8:13 pm
OnlyMe wrote:
......S-E There are times you may wish to fit an earth rod, eg you would need a massive earth cable to export the incoming earth due to extraneous conductive parts in the outbuilding, in which case it might make more sense to not export the earth, use a local earth rod and make the outbuilding a TT supply using the rod as the ONLY earth to the outbuilding and bonding the extraneous parts in the outbuilding to that earth rod.
Sorry for any miss-understanding, my question was directed at paul777, asking him why he thinks he should add an earth rod. I get the impression that he has just read bits here and bits there and so does not really understand the principals of what he proposes to do, and has subsequently seen an earth rod mentioned and thinks may be he should install one. :dunno:
PostPosted: Wed Oct 04, 2017 12:54 am
OK advice taken
just checking
thanks all
hoping to start next week thank you again
