It is currently Sat Jul 21, 2018 2:33 pm
PostPosted: Tue Sep 26, 2017 1:14 pm
Long story short, I am posting the video of my problem here:
(It is a 2005 Peugeot 206 1.4 HDi on 214k kms)
The car has been doing this for over a year now. Sometimes it is all fine for months, sometime the problem gets more severe. Few weeks ago, for the first time, the engine stopped on the move and did not start again for few minutes.
The only OBD code I read is about the air flow sensor. But I am not sure if that is the problem. Some mechanics say this is electrical-related, some say diesel pressure sensor.
ALSO, not sure if related to this or not but; I have experienced 2-3 times in the past months that the starter motor was completely out of order (not a single sound when I pressed the starter) and was able to start the engine only by push starting. After, the starter worked normally...
The prices they talk are really high and I doubt giving it away when the problem is not properly diagnosed. Any ideas on this problem?
PostPosted: Tue Sep 26, 2017 2:19 pm
Has thanked: 49 times
Been thanked: 518 times
Test the fuel rail pressure
looking at that, I would say its related to the turbo as it seems to be dropping pressure, noting the rev's drop as its building Pressure, I would say its the boost control solenoid or a map sensor going bad, its worth checking all the vacuum hoses too but it needs some move
Where are you from ? as its pointless giving you any links if you not in the uk
edit. the boost control solenoid is the weak point on Pug and Renault diesels, Renault have redesigned there part 7-8 times and still haven't got it right
PostPosted: Tue Sep 26, 2017 8:45 pm
UPDATE: Today I have made a visit to the local Bosch Diesel service, and to my surprise, their diagnosis device spotted a signal which others could not, and it is P0335 (Crank shaft sensor). It looks as a more probable cause to my problem, what do you say?
PostPosted: Fri Oct 13, 2017 11:57 am
Has thanked: 696 times
Been thanked: 28 times
Common fault I would replace and re scan
PostPosted: Fri Oct 13, 2017 12:08 pm
It could be a number of things, sensor breaking down under load - replace the sensor, A wiring fault or bad connector or a bad reluctor ring
If your going to replace the sensor replace it with a good quality item (Bosch) you can get cheap pattern part items for £25 (seem to be 2 types)
For this message the author Bob225 has received gratitude : multiman
PostPosted: Fri Oct 13, 2017 6:46 pm
Has thanked: 1452 times
Been thanked: 3725 times
Wiring fault or dodgy connection would explain intermittent nature of the fault and why it hasn't shown up on previous tests/interrogation
