It is currently Tue Jan 16, 2018 11:53 am
Visit Thermo worx
 Post subject: 15mm fitting
PostPosted: Mon Sep 25, 2017 6:30 pm
Has thanked: 30 times
Hiya,
Can anyone tell me what make/type of fitting these...
Ta
 Post subject: Re: 15mm fitting
PostPosted: Mon Sep 25, 2017 6:43 pm
Has thanked: 1357 times
Been thanked: 3502 times
Looks like John Guest (JG) from here. Plastic fantastic. Personally I'd replace with copper... :wink:
PostPosted: Mon Sep 25, 2017 6:56 pm
Has thanked: 134 times
Been thanked: 204 times
I think it's the old style (grey) Hep2O fittings. They've changed the design now -- and the colour (they're white). But you do occasionally see the old ones on sale still, especially online.
http://www.ebay.co.uk/itm/Hepworth-Hep2O-15mm-equal-tees-Hep20-Hep-2O-20-Push-fit-connectors/141235731876
The groups of 3 lines on the nuts give it away.
For this message the author chrrris has received gratitude : wine~o
PostPosted: Mon Sep 25, 2017 7:03 pm
Well spotted. One of the reasons I hate plastic fantastic fittings. A) difficult to identify B) are the bit's that you can get now compatible
PostPosted: Mon Sep 25, 2017 7:07 pm
Has thanked: 945 times
Been thanked: 1752 times
It's grey hep,I've a few of these in my gaff. They are under my sink and look naff.
PostPosted: Mon Sep 25, 2017 7:11 pm
Yeah. I'm not a fan of them myself either TBH. I guess they were used there because it looks like it might be a loft with lots of loose insulation about, but wherever pushfit fittings and plastic pipe are found, you're normally not very far from poor layout & unclipped pipework. :-)
PostPosted: Mon Sep 25, 2017 7:23 pm
They're under an upstairs floor and the ceiling below has been lowered and insulated. They feed a sink that I've moved and I thought I might replace them now that I've disturbed them & as they've prob been there 10 years +.
Thanks for the replies
PostPosted: Mon Sep 25, 2017 7:27 pm
IF they aren't leaking don't touch them.
PostPosted: Mon Sep 25, 2017 9:03 pm
Has thanked: 15 times
Been thanked: 37 times
I can confirm, as I have a (refurbished 2000) listed building full of them, that they are Hepworth (embossed on the fitting) Hep2o fittings and at first glance do not appear to be demountable (as is JG Speedfit).
However, firstly, with care they can be disconnected/reconnected without problem (for instance, removing an elbow & inserting a tee or vice versa).
Secondly, with care, they ARE reusable, at the expense of losing pipe. Undo the fitting, taking note of the order of assembly of the collar, 'o' ring, "gripper piece" and thumb-nut.
The "gripper piece" only slides onto the pipe in one direction, so cut the pipe (wasting a length) below/beyond the nut - it will then slide off. Reassemble the fitting in the correct order and it can easily be refitted to a new length of pipe without problem. I have done this many times over the last couple of years and have a boxful of spare parts. I have replanned/refitted two bathrooms and have not had to purchase ANY new fittings (not that I'm tight) or indeed, any barrier pipe.
The previous owner's plumbing left so much to spare, careful planning made all modifications simples. All the horrible grey stuff is totally hidden behind fitted units or underfloor. Initially, my consideration in re-using fittings stemmed from the fact that the incoming barrier pipe is immovably encased in the concrete floor, so I couldn't shorten pipes as described and was forced to reconnect Hep2o thumbnuts to a Hep2o fitting.
Yes, they are ugly, but not as ugly as current Speedfits (with thumbnut), the original demountable Speedfits were better IMHO. OK, copper may be preferred by many, but even then one could consider that (professionals') use of end-feed fittings, with solder, flux & green slime running out of them, is not as neat as a keen DIYer's careful use of Yorkshires. Another argument no doubt.
PostPosted: Tue Sep 26, 2017 1:07 am
If someone's doing end feed joints that look worse than DIYed yorkshire fittings, then I'd say they don't really have any business calling themselves a plumber. Obviously flux residue and green slime apply equally to yorkshire fittings as to end feed, but shouldn't be an issue in either case as the joints should be cleaned up after they're made to avoid pin-holing.
Users browsing this forum: caretaker and 1 guest
