It is currently Tue Jan 16, 2018 5:48 pm
Visit Thermo worx
 Post subject: The use of glass blocks
PostPosted: Thu Sep 21, 2017 7:26 pm
Has thanked: 57 times
Been thanked: 5 times
Greetings all,
I propose to install some of these to add light to my living room,which at present only
has daylight at the end of the room.
The outside wall is stark brickwork which needs a lift anyway.
What i'd like to do is to install 4 sets of 2 blocks,all in one horizontal line,
spaced 200mm apart,in the outer course of this cavity wall,at slightly
above head-height,flush with the existing brickwork.
I would cut slightly larger apatures on the inside wall,including fitting of 4 lintels,each 500mm long,
above the inside voids.
[ Behind the hanging tiles,the upper level is brieze block construction.]
So...2 questions: Can I avoid lintels over the glass bricks on the outside?
And...what would be the method of sealing the cavity exposed at
each of the 4 positions?
My thanks for reading.
Nigel
PostPosted: Sun Sep 24, 2017 8:28 pm
Perhaps a more direct question would help.
Can glass blocks be considered structural?
PostPosted: Mon Sep 25, 2017 8:54 pm
Old School Chippie
Has thanked: 623 times
Been thanked: 1295 times
Only ever seen them installed beneath some form of lintel, presumably because they are non-strucural. They are, after all, breakable
OK, I'm an "old school" chippie, so please don't ask me to do a bodge job - I didn't bring my horse today and in any case you don't seem to have a hitching rail!
PostPosted: Mon Sep 25, 2017 9:44 pm
Has thanked: 15 times
Been thanked: 37 times
So is a brick.
Most Building Control Officers are approachable, if you can get one to answer his phone, so ring up & ask the question.
For this message the author arco_iris has received gratitude : Nigel 206
