It is currently Mon Sep 24, 2018 6:29 pm
 Post subject: Shed wiring
PostPosted: Thu Aug 10, 2017 8:12 pm
Has thanked: 3 times
Been thanked: 2 times
Hi all
I have a shed which is fed from a 13A FCU in the Kitchen. Inside the shed, SWA cable goes straight into a socket. There is one FCU on a spur from that socket that feeds a fluorescent light. I would like to add two led spotlights to the wall so I can see whilst I work. How should I do this? My socket can fit no more wires in it and I don't want them connected to flex.
Any help :help:
James ::b
 Post subject: Re: Shed wiring
PostPosted: Thu Aug 10, 2017 9:01 pm
Has thanked: 64 times
Been thanked: 541 times
Either the output from the FCU in shed or the fluorescent, I would assume a switched FCU and that switch turns lights on and off?
PostPosted: Fri Aug 11, 2017 12:19 am
Has thanked: 696 times
Been thanked: 28 times
You would take live or switched feed from fluorescent tube fitting if you used switched when fluorescent tube is on spotlights will be on
PostPosted: Fri Aug 11, 2017 9:13 am
Thanks for your replies!
Yes it is a switched FCU.
Could I replace the switched FCU with an unswitched and then use junction boxes to have two separate switches for the lights (like a lighting circuit)?
James :huray:
PostPosted: Fri Aug 11, 2017 9:26 am
Yes you could replace fcu and add your own switches into circuit
For this message the author multiman has received gratitude : is an idiot
PostPosted: Fri Aug 11, 2017 9:35 am
Thanks!!!! :huray:
For this message the author is an idiot has received gratitude : multiman
PostPosted: Fri Aug 11, 2017 9:40 am
To be honest you could keep fcu you already have and add switches after that
PostPosted: Fri Aug 11, 2017 10:13 am
True. Think I may keep it.
